Nodetree update optimization from Blender 3.1+ breaks my Addon #101378
Reference: blender/blender#101378
Operating system: -
Graphics card: -
Broken: 3.1+
Worked: 3.0.1
I'm the creator of Material Wizard Addon (https://wp.h0bb1t.de/index.php/about-material-wizard/) and have to admit, that I haven't touched it quite a long time. I now have planned to update it and stumbled across the fact, that it doesn't work as expected starting with Blender 3.1+. After some debugging, I figured out where the problem comes from and assume it is related to the Nodetree update optimization started in 3.1.
Material Wizard has its own Node Tree and reflects any changes to it in different Shader Node Trees. It does it by creating hidden NodeGroups and instanciate them in the respective material and links sockets according the settings in my own node space. Long story short, the problem arises when adding a node group to the shader node tree and try to loop over the inputs of this node group. It seems in Blender 3.1+, the inputs do not reflect the inputs of the node tree embedded to the group:
In the highlighted area in the lower left corner, len(node.inputs) is 0, while len(node.node_tree.inputs) is 8. In Blender pre 3.1, the first one was also 8, which is what I need. After my script has run, I get the correct node groups in my target material trees, but they don't have inputs or outputs. Subsequent calls to [Node.update()] in Blenders Python console fixes the problem.
I assume I need to force an update on the Shader Node Tree from my script, but havn't found any information how to do this. Calling update() on the node in my script (rectangular highlighted area in the code above) doesn't seem to help.
Please help me.
Thanks,
Thomas
Added subscriber: @h0bB1T
Please try to reproduce the issue outside of your addon to make it easier to investigate for us.
Ok, I've quickly hacked a script based on the custom nodes template that shows the problem. Tested with Blender 3.0 & 3.2, 3.2 is affected (but I assume 3.1+).
In the default scene:
Adding the group to TestMasterial Shift-A/Group/TestNode fixes the problem.
Running create_node_group() + add_node_group() from script directly works as expected.
I hope this helps.
Hello Jacques,
in D16070 you mention there would be better ways to do this. I'm always open to better ways. As it is just a call to rebuild_tree, it's relatively fast to test different ways. What is the preferred way to let the Shader Node Tree stay in sync with my custom tree?
And, in case of your mentioned timer based solution, would it be ok (incrementally) sync tree layout on an e.g. 100ms timed cycle?
It's not perfect but you could set some flag to true in the update function and then just check that flag in a timer so that it only syncs the tree when necessary. I'm not sure if there is a perfect solution for this scenario currently.
Thanks, will try this :)
Any update here? Did you find a solution @h0bB1T ?
Hi. Yes. I followed the idea of Jaques to use a dirty flag and a timer based update and it works nicely. At the end, it seems the better solution. So at least to my needs, it is not necessary to fix it (and the new solution works in older Blender versions too).
Great, thanks for your quick response. I am closing this then. :)
