Geometry Nodes: different behavior when beveling #101427
Closed
opened 2022-09-28 10:25:48 +02:00 by Marco · 11 comments
Member
Broken: 3.3
Worked: 3.2.2
Somehow the behavior of either the Geometry Nodes or the Bevel modifier is different between version 3.2 and 3.3.
What's the change causing this behavior?
Test.blend
**Blender Version** Broken: 3.3 Worked: 3.2.2 **Short description of error** ![screenshot.jpg](https://archive.blender.org/developer/F13586405/screenshot.jpg) Somehow the behavior of either the Geometry Nodes or the Bevel modifier is different between version 3.2 and 3.3. What's the change causing this behavior? **Exact steps for others to reproduce the error** [Test.blend](https://archive.blender.org/developer/F13586413/Test.blend)
Author
Member
Added subscriber: @nacioss
Member
Added subscriber: @OmarEmaraDev
Member
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Member
It seems 3.2 stored the attribute as a Vertex Group, which can be seen by applying the GN modifier. While in 3.3, it is stored as an attribute, and it doesn't work due to #100042.
Not sure if this is expected, so tagging the module for more information.
It seems 3.2 stored the attribute as a Vertex Group, which can be seen by applying the GN modifier. While in 3.3, it is stored as an attribute, and it doesn't work due to #100042. Not sure if this is expected, so tagging the module for more information.
Contributor
Added subscriber: @persun
Added subscriber: @mod_moder
The long term plan is to move away from vertex groups in favor of attributes, so that's probably fine.
In addition, it seems that attributes can only be used within nodes so far.
The long term plan is to move away from vertex groups in favor of attributes, so that's probably fine. In addition, it seems that attributes can only be used within nodes so far.
Author
Member
Ok fine, then my question is, in this example, how can I tell the Bevel Modifier to affect only specific vertices?
If you create an attribute and edit it with attribute edit modifiers, without geonodes, then everything should be fine, I think
Member
Closed as duplicate of #99197
Author
Member
The issue is that I need to do the beveling only on specific vertices which are selected only in the GeoNodes setup, what would be a workaround for doing that?
5 Participants
Reference: blender/blender#101427
