VSE: Hard cut does not cut correctly cut strip when speed factor is greater than 1 or differing framerates #101447
Reference: blender/blender#101447
Operating system: Windows 11
Graphics card: RTX 3090
Broken: 3.30,
0759f671ce
, 2022-09-06 15:39Worked: N/A - Speed factor option not available before 3.30
When using hard cut in the VSE (Shift+K) on a strip that either has a speed factor other than 1.0 or where the strip is recorded at a different framerate to the output target, the hard cut will not behave as expected. For speeds greater than 1.0 the initial strip will not end at the cut, but will instead run longer, and the second half of the strip will not start at the cut point. The strips will overlap on the same channel. For speeds less than 1.0 there will only be the second half of the cut and the initial part of the strip will disappear.
If the source and target framerates do not match (e.g. output framerate of 30FPS, input strip of 60FPS) it will behave as if there is a speed factor equivalent to the framerate difference applied. (e.g. in the previous example, as if there is a speed factor of 2.0).
As a workaround it is possible to cut strips at 1.0 speed factor and then adjust speed factor on the cut strips afterwards.
Added subscriber: @direkteffekt
This issue was referenced by
295eb04ba3
957cb173f2
