Geometry Node: Vector in face corner domain have different interpolation method unlike general uv for subdivision #102189
Reference: blender/blender#102189
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.40
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
Worked: Never
The UV island interpolation algorithm allowed the mesh and texture coordinates to intersect freely to keep lines parallel when subdivided.
When using the general vector attribute, the subdivision uses simple averaging.
The result of this is that geometrically parallel lines can be visually curved.
2022-11-01 21-42-33.mp4
Subdivide an arbitrary mesh with common vector attributes and build a grid on the render from them to see the deformation.
Or check the example file:
FaceCornerVectorNotUVforSubdiv.blend
Added subscriber: @Rincewind3D-1
Added subscriber: @mod_moder
#85962
Checking...
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
So far, I see that the problem is simply in the subdivision. More precisely, perhaps it is his method of interpolation. Need a higher opinion.
Interesting, yes in this the example file it's the subdivision.
But in my real-world project, there's also a distortion in the base mesh without subdivision.
Not sure what's here different from my simplified example with Suzanne. Unfortunately, I can't share my real-world example, but here are two screens of the distorted UV, just by adding the geometry node to the base mesh:
However, both UV distortions are serious issues for displacement maps.
I try to investigate more and hopefully find a way for a simplified example for the other issues and make a second ticket for that one separately.
I can imagine that this may have something to do with the fact that UVs are in nodes, this is a 3d vector. Maybe changing the 3rd axis can somehow affect this offset. But that's just my guess. If you want to explore this, you can also pay attention to it.
I figured out what the other distortion caused I mentioned: It's a mask modifier.
So we have two different types of UV distortion:
The UV distortion, which is caused by the mask modifier, seems not to hurt my displacement textures, so I guess it's, for now, a non-issue and can be ignored.
The one caused by geo-node and subdivision is still an issue and should be continued to inspect by the developers.
Okay, it looks like I was too fast with my conclusion.
A mask modifier distorts the mesh in combination with that geo-node while using base mesh.
That's probably an issue. I will investigate more and then create for that second issue a separate ticket.
Geo node join and merge by distance distorts the UV mapto Geometry Node: Vector in face corner domain have different interpolation method unlike general uv for subdivisionChanged status from 'Needs Developer To Reproduce' to: 'Confirmed'
Hello again. Thanks for the report. After a little investigation, I can confirm this report, as well as slightly modify it to be more specific about the problem you describe. If you have any other errors not related to this case, you can open new reports with new examples.
Thanks for the report. I wouldn't call this a bug though. The attribute created by the Store Named Attribute node isn't a UV map, so it doesn't get the special UV map interpolation during subdivision. There are two ideas to address this:
f0dc4d67e5
combined with D14365@HooglyBoogly
Just tested this one in 3.5 Alpha.
Of course, still broken ;)
Is there any design task for "adding meta-data to attributes when creating them to change how they're interpolated" yet? ;)
@HooglyBoogly
was is this issue closed?
It's still not fixed.
It should work better now, if the data is stored as a 2D vector attribute on the face corner domain by the store named attribute node.
Unfortunatelly, can't confirm.
In the Blend file at the start of this ticket, the UV map still deforms like it was before:
You're using the 3D vector type, not 2D.
confirmed, but is fixed. Also my original example is now working which was replaced is now working as intented.
sadly I can't test my real world example, where I discovered this issue, after Blender is crashing when I start rendering in Cycles ;)
But this is an other ticket, once I gathered more details.
thanks.
I created a follow up.
There seems to be still an issue with normals: #106578
The crash seems to be related to hair paticles. I will also create a follow up once I have a simpilfied reproducable test case.
