(Camera) Motion blur renders wrong (does not cancel out) when a mix of parenting and (baked) object animation is used #102521
2 Participants
Reference: blender/blender#102521
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA RTX A6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.94
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
when I parant a camera (looking for a simple cube) and the cube (who is the camera looking for it) to any other object, if the parent object is rotating, it will rendered fine but if I baked the action of the camera, and renderd the same frame it will be very in coorect motion blur, to fix the issue I have to bake the camera and all the objcects that appear on it,
motion blur bug.blend
open the attached blend file, you will find a very simple scene with a camera, cube and a light are parented to a rotating empty object, just press render at frame 2 (which at the meddle of rotation) and it will render the motion blur very good (you will not see any motion blur which is logic because the camera and the cube are parended to the same object), but after that just bake only the camera (with selected object, visual keying and clear parent enabled) and render the same frame, it will give very unlogic motion blur, after that bake also the cube and the light and redner the same frame, it will render very good, this issue is only on rotating parent object bun in location it works very good, also I tested it on blender 2.7 and the same issue are there
Added subscriber: @rfc
Added subscriber: @lichtwerk
Can confirm the issue.
I believe this has been reported before (but cannot find the duplicate atm.)
Same is true if the camera stays parented and the other objects are baked instead.
It is not mentioned here (but should, if it turns out to be a Known Limitation) https://docs.blender.org/manual/en/3.5/render/cycles/render_settings/motion_blur.html#limitations
Motion blur issue after baked camerato (Camera) Motion blur renders wrong (does not cancel out) when a mix of parenting and (baked) object animation is used
