Unable to select multiple Grease Pencil layers with Python #103329
6 Participants
Reference: blender/blender#103329
Operating system:
Graphics card:
Broken: 3.4
Worked:
Setting the Grease Pencil Layer property "select" with Python doesn't seem to work. Tried various update tags with no luck. Similar layer properties, such as the booleans "lock" and "hide", work as expected with the same code as below.
select_bug.blend
Open Blender from a console/terminal and keep that window in view, open the attached .blend, click the play button in the Text Editor header to run the example script (which sets all layers' select property to True), then hover the mouse cursor over the Python console and press Enter to run the command: print([gpl for gpl in bpy.context.object.data.layers if gpl.select])
Added subscriber: @bunny
#104226 was marked as duplicate of this issue
Added subscriber: @mano-wii
The code returns as expected, but it seems that some update is missing.
Added subscriber: @antoniov
@bunny what you want to do? select the layer in the properties list? First, you can select only one layer at time and this is done using layer
active_index
. Theselect
is a property for the internal Dopesheet channel selection but is not related to the grease pencil active layer.When animating, I interact with layers exclusively in the Dope Sheet, where multiple layers can be selected by shift-clicking the channels in a familiar way.
I've written operators and app handlers which live in the Dope Sheet and affect all such selected layers by using the list comprehension [gpl for gpl in gpd.layers if gpl.select] to mimic context access. That works great when everything is contained within a single execute function, but what I want to do is be able to select layers in the Dope Sheet (which match some potentially complex condition) with one operator and then operate on those selected layers with a different operator -- one even belonging to an entirely separate addon.
This would make it possible to "chain" smaller operators as is possible elsewhere (a good example might be the Bone Selection Sets addon), even across different addons, rather than always having to have both the "select routine" and the "execute routine" in the same operator, which can end up causing code duplication and too many operator properties/arguments. For instance, often only the "select routine" is needed, when that select prop affects an app handler.
Added subscriber: @amelief
@bunny If you want work with the dopesheet channels, then use the layers maybe is not the best solution. @amelief You know very well the dopesheet code. Could you advice how to do this in python? or maybe, you know what notifier is missing in the RNA code (line
1825
inrna_gpencil.c
)If I understand correctly, it's about the
select
flag of the layer and not the frame (so it would be line2236
instead of1825
inrna_gpencil.c
), right ?I am not sure it's a missing notifier issue. Notifiers in are the same than for the
lock
flag, and that one is working properly.Plus, if I open the standard "New 2D animation" file, and try to change selection of layer "Fills" in the console I get this :
So it seems that the flag is not updated at all.
By the way, there is also a missing notifier for the
select
tag of the frame.I think this should be dealt with in another issue. It seems really easy to fix.
Added subscriber: @lichtwerk
@amelief : this just seems to miss
ND_ANIMCHAN | NA_EDITED
in theRNA_def_property_update
@lichtwerk You are right, good catch ! :) I wonder if all notifiers flags are needed, cause now we'd have
ND_ANIMCHAN | NA_EDITED | NC_GPENCIL | ND_DATA | NA_SELECTED
@amelief : in fact, just swapping
NA_SELECTED
withNA_EDITED
is enoughSo
Perfect ! Do you want to do the patch for this @lichtwerk or should I do it ?
I will create an issue for frame selection update, and the fix diff for it.
@amelief : go ahead. (it would still be nice to do a bit of digging in regards to why
NA_SELECTED
seems to work just fine on some layer props (active_index
,lock
, ...) but not on others, havent done this research... patch would probably go through without, but it is always good to justify changes with a proper reasoning)@lichtwerk Yes, I was thinking the same. Actually, for grease pencil api at least, it is only used for
active
andactive_index
, and notlock
, which makes sense.I do not know how this notifier flags work, I guess
NA_SELECTED
only checks the active elements in grease pencil and do not dig into selected frames/layers.But then, for frame selection,
seems to be enough, so it seems confusing (see D16832)The listener
action_listener
only has the difference of settingSACTION_RUNTIME_FLAG_NEED_CHAN_SYNC
(in case ofNA_SELECTED
vsNA_EDITED
) As a consequence,animchan_sync_gplayer
clearsGP_LAYER_SELECT
(when the layer is not also active)c5338fd162
is the relevant commit here.So an idea would be to isolate SACTION_RUNTIME_FLAG_NEED_CHAN_SYNC to actions actually involving changing the
active
status (and not do it for everythingselection
)We could use the notifier action NA_ACTIVATED, to make this more explicit (note I havent tested this thouroughly)
P3405: T103329_snippet
@antoniov , @amelief : mind giving this a good testrun? (seems to work as expected in simple test UI wise -- so clicking on channels will make the layer active in the Properties Editor, clicking on a layer in the Properties Editor wil select its channel plus the script presented here also works)
Hey @lichtwerk , I've tested it and it seems to work. My only concern is that
NA_SELECTED
seems to be widely used in the code of grease pencil, especially when it comes to layers. So we actually have to go through each of them to se if they change theactive
flag or not. I can start on that, but it could take some time.@amelief : thx testing! If you could check on
NA_SELECTED
(and possibly change the occurances where activation is required toNA_ACTIVATED
) that would be awesome!One thing that may be weird with our solution is that one layer could be selected while another is active (and not selected). In this case the interface shows unconsistent information, as in this image. Wouldn't that be an issue ? Maybe @antoniov you have an opinion on this.
I don't know how these things work with object selection for example
Added subscriber: @KevinCBurke
