The Select Hierarchy keyboard shortcut fails to select nested meshes #103723
Reference: blender/blender#103723
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: Quadro #2000 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.94
Broken: version: 3.4.0, branch: blender-v3.4-release, commit date: 2022-12-06 18:46, hash:
a95bf1ac01
In the Outliner, Select Hierarchy on the context menu works as expected. The corresponding keyboard shortcut (Shift-RightBracket) fails to select meshes that are nested in an empty.
Select_Hierarchy_keyboard_shortcut.blend
Added subscriber: @EightSix
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Hi, thanks for the report. Nested objects can still be selected with multiple
select_hierarchy
callFrom code side, we're not checking childern object recursively: here :
select_new.extend([child for child in obj.children if child.visible_get()])
Not sure if this was done intentionally. Forwarding to devs
But this can be fixed by replacing
obj.children
toobj.children_recursive
Hi @pratik-2,
Thank you for that solution—it worked beautifully!
Right before I saw your message I discovered that I can press Shift ] multiple times in a row to extend the selection down into the hierarchy. That's good news insofar as there is a way. But in addition to my concern that its behavior is inconsistent with the command of the same name in the Outliner:
There may be a very valid use case for the shortcut behaving differently, but if that's the case, then I'd propose to the devs:
Added subscriber: @pratik-2
Removed subscriber: @pratik-2
Hi, which function you're calling in new shortcut? I'm not able to select entire hierarchy by doing so.
Of course we could either rename the keymap or commit the proposed solution from above
I changed obj.children to obj.children_recursive in object.py and Shift ] is grabbing what I need. Here's a screenshot of it working in the blend file attached to this report.
I may have mis-worded my last message. I was suggesting either:
or
Added subscriber: @1D_Inc
A tiny bit if context.
I think such a behaviour was made to provide correspondance to viewport action - for example it is useful for navigating bones.
I think it is reasonable to add a recursive method to the both viewport and outliner parenting hierarchies as ctrl+] or ctrl+shift+] and also keep them corresponding with viewport actions.
(For example, Shift part stands for "expanding" and ctrl part stands for "recursive")
Alt hotkey usually mean "antiaction" (for example, alt+G, atl+R resets objects transform), it is better to keep use it in that way (this is not the case for using Alt).
In mesh modeling L hotkey allow to select the entire mesh chunk/island on mouse hover, but as far as I remembel there is no such an action available for parenting hierarchies in object mode while is demanded.
Quite similar behaviour can be found in nodes handling as well, so linear hierarchies handling behaviour is supposed to be unified across the program.
Also, a side note, autoselecting the entire hierarchy by picking some its part is a behaviour of a common groups paradigm, which was requested is not presented in Blender yet because of cumulativity of a collections (the ability to store the same object in multiple collections) which is not compatible with linear hierarchies.
This suggestion looks perfect. Lets wait for module devs answer as there is now clear indication how
select hierarchy
should behave.cc @pablovazquez
