It seems that this modifier was forgotten and it did not appear at all in the deform2rvk script ( and there was also one or two lines in double in the modifier.c file).
If the patch is approved, a patch to the Deform2rvk script will be posted too.
A new version, I added :
TYPES,
VERTGROUP
RELATIVE settings.
So it is less short than yesterday.
A new version (again, sorry) V3, I added :
LOWER_LIMIT,
UPPER_LIMIT,
LOCK_AXIS_X,
LOCK_AXIS_Y settings.
I added a lot of settings to the shrinkwrap modifier too :
- OBJECT_AUX - Used for Shrinkwrap only, (Object)
- KEEPDIST - Used for Shrinkwrap only (float [-1000.0, 1000.0, default: 0.0)
- PROJECT_OVER_X_AXIS - Used for Shrinkwrap only, should the modifier not project over normal (bool)
- PROJECT_OVER_Y_AXIS - Used for Shrinkwrap only, should the modifier not project over normal (bool)
- PROJECT_OVER_Z_AXIS - Used for Shrinkwrap only, should the modifier not project over normal (bool)
- PROJECT_OVER_NORMAL - Used for Shrinkwrap only (bool)
- ALLOW_POS_DIR - Used for Shrinkwrap only, should the modifier use Project TYPES (bool)
- ALLOW_NEG_DIR - Used for Shrinkwrap only, should the modifier use Project TYPES (bool)
- CULL_TARGET_FRONTFACE - Used for Shrinkwrap only, should the modifier use Project TYPES (bool)
- CULL_TARGET_BACKFACE - Used for Shrinkwrap only, should the modifier use Project TYPES (bool)
- KEEP_ABOVE_SURFACE - Used for Shrinkwrap only , should the modifier use Nearest Surface TYPES(bool)
- SUBSURFLEVELS - Used for Shrinkwrap only (int [0 - 6]). The number of subdivision levels used.
And the modifier.py docfile was updated, of course.
I'll try to take a look at this Monday; we're in exam week here at the university. I'd like to sneak this into 2.49 if possible.
