Object: Fracture tools #21793
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
14 Participants
Reference: blender/blender-addons#21793
Project: Blender Extensions
Tracker: Py Scripts Release
Blender: 2.64
Python: 3.2
Script name: Object: Fracture Tools
Homepage: http://blenderartists.org/forum/showthread.php?t=181391
Wiki page: http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/Object/Fracture
Author(s): pildanovak (vilda)
Category: Object
SVN Download: https://svn.blender.org/svnroot/bf-extensions/trunk/py/scripts/addons/object_fracture/
Status: Open
%%%Short tutorial:
1.Download and install extension. go to preferences->addons>install, find the .zip file(do not unpack it yourself, installer does). Then enable the Fracture extension.
2. create a manifold mesh(cube), space-search fracture object operator, run it.
3. Tweak the operator properties in the last operator area. then check execute. The operator tweaking isn't possible since that point. If you set up a lot of shards, you'll have to wait.
4. select all the shards you want to take part in explosion. Then search and run the Setup shards operator.
5. run these 2 operators: Add rigidbody recorder, Add bomb.
6. you can place the bomb whereever you want, and tweak it's properties in the logic window. prop names should be self explanatory.
7. Select the shards.
8. Run the game engine.
9. After leaving engine, your animation should be baked.
Notes:
there is allready game engine recording feature in 2.5, so theoretically this could be redone to not use the recorder, but now you have to use it because it also freezes objects in the beginning. I also consider the possibility to re-bake just the selected shards much better than baking all rigidbodies in the scene...
No projectile or 'active shard' feature from 2.49, not possible with 2.5 now.
Also no 2d version(no acces to images from rna yet ), no voronoi yet e.t.c. I have now very few time for this, so anybody wanting to play with the code is welcome. It's very simple, just few lines of code!%%%
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the #Addons project page for more information on the workflow.
%%%Fixed archive fracture.zip
fracture.rar is obsolete%%%
%%%New fracture.zip
%%%The script is available in bf-extensions trunk now (r562++).%%%
%%%in version 2.0 script return errors
in ubuntu 10.04, with http://ppa.launchpad.net/cheleb/blender-svn/ubuntu for download blender and addons%%%
%%%- marked as no wiki
wikipage is there but massively incomplete.%%%
%%%I fixed errors in bomb and recorder script, caused by the Python API changes. It should work with Blender 2.56.6 now.%%%
%%%Reported & confirmed broken in Release 2.57%%%
%%%I think I found and fixed the problem – was line 217 in fracture_ops.py
Attached the fixed (I hope) version.%%%
%%%Bah, in fact, there are other problems as well – will try to check all today…%%%
%%%Updated data.blend for py api changes...
current_frame --> frame_current
object.selected ---> object.select
Check for default__cam name and ignore in recorder script (threw errors if nothing was selected)
Also if the user added a projectile it would never collide with teh broken objects as it was looking for game property "age" when the pieces have game property "shard"... Fixed, checked and it works.%%%
%%%Bug fixes:
*bpy.ops.object.duplicate(linked=False, mode=1) → bpy.ops.object.duplicate(linked=False, mode='DUMMY')
*Only 20 layers in Blender! (rem lines 72-74)
Enhancements:
*Commented out non-manifold check on returned shards (lines 234-235)
*Modified Fracture Group UI (now using custom draw func, to be able to search existing groups without having to reload the whole Python!)
Also, updated API version to 36147.%%%
%%%As I was at it, I made a few enhancements (I hope!) to that nice tool… So here is a 2.1 proposition :)
Heavily reviewed fracture group behavior:
Also changed UI part:
All this in attached file!
%%%An update (correcting a bug in bbox intersection detection, and a few UI improvements).%%%
%%%Bastien, i think your last commits broke something...
[code]
Boolean code using new merge technique.
TypeError: Converting py args to operator properties: OBJECT_OT_duplicate.mode expected a string enum or a set of strings in ('INIT', 'DUMMY', 'TRANSLATION', 'ROTATION', 'RESIZE', 'TOSPHERE', 'SHEAR', 'WARP', 'SHRINKFATTEN', 'TILT', 'TRACKBALL', 'PUSHPULL', 'CREASE', 'MIRROR', 'BONE_SIZE', 'BONE_ENVELOPE', 'CURVE_SHRINKFATTEN', 'BONE_ROLL', 'TIME_TRANSLATE', 'TIME_SLIDE', 'TIME_SCALE', 'TIME_EXTEND', 'BAKE_TIME', 'BEVEL', 'BWEIGHT', 'ALIGN', 'EDGESLIDE', 'SEQSLIDE'), not int
[/code]%%%
%%%Michael, I don’t know whether you talk about my last svn commit, or my 2.1 proposition (which I didn’t commit in svn), but you are using neither of those… The line in your trace back…
File "/home/michael/svn-blender/install/linux2/2.57/scripts/addons/object_fracture/fracture_ops.py", line 217, in boolop bpy.ops.object.duplicate(linked=False, mode=1)
…was one of the fixes I have to make, as the object.duplicate() op now needs a string as mode parameter (I used the 'DUMMY' one).
So please check that you really have the latest svn version of fracture, and test again…%%%
%%%Ah, i don't know if i'm just missing some obscure setting, but this Add-on doesn't seem to be working on 3 out of my 4 machines. On my MacPro1,1 running 10.5.6 it seems to work, but on my MacPro3,1 also running 10.5.6, HP Touchsmart running windows7 and my Asus X55 running Ubuntu 10.10 nothing seems to happen when i press the execute check box.%%%
%%%That’s weird ! Could you please post logs from the console ? And are you sure you have the same svn version of the script on all your machines (it was modified recently) ?%%%
%%%As best as i can tell, they should all be running the same 2.0 version of the script that came stock with Blender2.7 on release. This is basically what all the machines are putting out except for the MacPro1,1:
bpy.ops.object.fracture_simple(exe=False, hierarchy=False, nshards=5, crack_type='FLAT', roughness=0.5)
bpy.ops.mesh.primitive_cube_add(view_align=False, enter_editmode=False, location=(0, 0, 0), rotation=(0, 0, 0), layers=(True, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False, False))
bpy.ops.object.editmode_toggle()
bpy.ops.mesh.faces_shade_smooth()
bpy.ops.uv.reset()
bpy.ops.object.select_all(action='TOGGLE')
bpy.ops.object.modifier_add(type='BOOLEAN')
It doesn't actually give me any python syntax errors, however the MacPro seems to run the exact same console code, except it does it 25 times (ie that's how many shards i choose) so my thinking is that there may be some run time error in the code that causes the other machines to default to 1 shard. So as far as the python API is concerned, the code is running properly, but the because i thinks you only want 1 shard when you fracture the object it outputs the whole object as a single shard.%%%
%%%Well, if there’s no Python error, it’s gonna be hard to trace it… I’ll see if I can do something, but I do not swear anything…%%%
%%%Hi!
Since your script is now in bf-extensions' svn (contrib|trunk) we have deleted the current attachments to avoid that end-users could reach this page and get the wrong version of your script.
Note that your script may have api changes or small maintenence changes applied in SVN.
Please retrieve your script from SVN before updating SVN to avoid mis-versioned scripts.
Thanks!
%%%Hi, thanks for this very useful script.
I tried it since several months, sometimes it worked and sometimes doesn't but I didn't understand why.
And today I find the cause of my problem. Fracture Object only works on Layer 1. If I try to use it on the other layers, I get this error in the console:
RuntimeError: Operator bpy.ops.object.editmode_toggle.poll() failed, context is incorrect
It's just an annoying bug, not a real trouble, though.%%%
%%%[canned response]
Hi, can you prepare a wiki page with a bit of a manual about how to
use this?
See
http://wiki.blender.org/index.php/Dev:2.5/Py/Scripts/Guidelines/Addons
Thanks!%%%
%%%Please try to expand the documentation a bit, including the different options and parameters.%%%
%%%hi, script is broken in bmesh, svn 44275
fracture script, fracture object, crack type spherical rough crashes blender completely.%%%
%%%Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
%%%Hi,
This addon seems to have a bug when dealing with UV coordinates on object that have been mirrored.
Step to reproduce:
The originaly real side is stil well textured, the other have its UV coordinate messed up.%%%
%%%Additional info:
http://pasteall.org/pic/show.php?id=42529
http://www.pasteall.org/pic/show.php?id=42530
Blender 2.65%%%
%%%Bug reported about "Setup fracture shards" operator, but it's working correct as far as I can tell so closed it.
http://projects.blender.org/tracker/index.php?func=detail&aid=36071&group_id=9&atid=498
The name could perhaps be changed to indicate that this operator sets up game engine physics settings, that's not really clear.%%%
Added subscriber: @k.sravangupta
hello,
please could any one help me..
I am getting error as,
Traceback(most recent call last):
whenever I try to export my blender files in to OGRE meshes and scenes I am getting this error please any one could help me..Its very important for me
