MD2 Plugin writes invalid files #23719
Reference: blender/blender#23719
%%%The MD2 Export plugin writes invalid files. The light normal index n should fulfill 0 <= n < 162, but it happens to write a light normal index of 162.
This should be the relating code:
swap y and x for difference in axis orientation
x1=-mesh.verts[vert_counter].no[1]
y1=mesh.verts[vert_counter].no[0]
z1=mesh.verts[vert_counter].no[2]
for j in xrange(0,162):
#dot = (x- [x]y- [x]+x- [x]y- [x]+x- [x]y[2])
dot = (x1MD2_NORMALS- [x][0]+
y1MD2_NORMALS- [x][1]+
z1MD2_NORMALS- [x][2]);
if (dot > maxdot):
maxdot = dot;
maxdotindex = j;
md2.frames[frame_counter].vertices[vert_counter].lightnormalindex=maxdotindex+2
del maxdot, maxdotindex
xrange(0, 162) iterates from 0, 1, ..., 161. What is weired is the value of 2 which is added to the normal index.%%%
%%%I'm not familiar with this format but there was a patch to remove the +2
Could you read this and see if theres a good reason to add it back? how are you viewing the md2?
https://projects.blender.org/tracker/index.php?func=detail&aid=19206%%%
%%%I don't see any reason to add the "+2" back again. From my understanding of the code the "+2" is wrong.
I was also following this spec
to create an application which loads MD2 models.
I just looked at to Quake 2 source code. Therefore I'm pretty sure that the value of the normal index must not be larger than or equal to 162.%%%
%%%in the code you show there is the +2 added back, could you provide a patch?%%%
%%%Here is the patch, to remove the +2. To apply it, go to the directory where the file "md2_export.py" is in and run
$ patch < blender_md2_normal.diff
. I was not able to locate the file in the repository. Is it maintained somewhere else?%%%
Added subscriber: @mont29
Time to archive I guess…
