relative and absolute path issue #23726
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#23726
%%%Here is a video about the issue:
http://www.vimeo.com/14794857
The problem is that I can't change relative path into absolute path
using os.path.abspath(path) but if I change the filepath from
"//..\Desktop\' into '/..\Desktop\' then the command os.path.abspath(path)
works. Thanks.%%%
%%%the // prefix is a blender only convention
use: bpy.path.abspath()%%%
%%%bpy.path.abspath() dosen't work. I would expect it will give something like c:\tmp\ for example. It dosen't change relative path into absolute. %%%
Added subscriber: @SebastianRothlisberger
Abspath is not working on own StringProperty:
I have a String Property as Filepath:
When i have relative Path in Preferences - File active, The Filebrowser opens with Relative Path checked.
This results in the StringProperty saved as:
Using Abspath on this gives either:
or:
removing the first / so the path looks like:
/../../../../Grafiken/Vorlagen/PhotogrammetrySamples/NEW_Munster/
gives this:
Added subscriber: @brecht
I don't see the bug? You probably want to do this:
bpy.path.abspath
will replace the//
Blender specific prefix, but it will not 'clean' the..
's from the path.Hmm, this works, thanks.
This then simply means i don't understand what i'm doing ;-) Thanks again brecht, have a nice evening.
