Import a HiRISE DTM formatted as a PDS IMG file #24897
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#24897
Project: Blender Extensions
Tracker: Py Scripts Release
Blender: 2.64
Script name: Import HiRISE DTM from PDS IMG
Wiki page: http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/File_I-O/HiRISE_DTM_from_PDS_IMG
Author(s): Tim Spriggs
Category: Import Export
SVN Download: https://svn.blender.org/svnroot/bf-extensions/trunk/py/scripts/addons/io_convert_image_to_mesh_img/
Status: Open
Related: 25462
%%%Features
Setup
Manual
http://www.uahirise.org/PDS/DTM/PSP/ORB_006800_006899/PSP_006899_1330_PSP_006965_1330/DTEEC_006899_1330_006965_1330_U01.IMG
Binning Methods:
2x2: create one value for each 2x2 region of the DTM by averaging them
6x6: create one value for each 6x6 region of the DTM by averaging them
6x6 Fast: create one value for each 6x6 region of the DTM by sampling a single value
12x12: create one value for each 12x12 region of the DTM by averaging them
12x12 Fast: create one value for each 12x12 region of the DTM by sampling a single value
12x12 is best for initial development of a scene to create very fast renders.
6x6 is better for proofing and even final products
2x2 is good for using a lot of CPU hours
None is good for small DTMs or computers built after 2015
Notes:
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the #Addons project page for more information on the workflow.
%%%I was given a kind hint in IRC:
14:28 < mindrones> rootard_ woo cool :) it's not an addons tho
14:28 < rootard_> ?
14:29 < mindrones> rootard_ to be an addon it has to go in addons/ folder so that it cna be enabled/disabled at will
14:29 < mindrones> rootard_ like it is now it simply is in blender by default
14:30 < mindrones> rootard_ have a look at scripts in addons/
14:33 < rootard_> mindrones: k, so I need the bl_addon_info dict... I'll rework some of it.
14:35 < mindrones> rootard_ yeps, also, have a read at http://wiki.blender.org/index.php/Dev:Py/Sharing
... so I reworked it and tested. Now the updated script should go into "addons/io_mesh_img" instead of "scripts/op/io_mesh_img"%%%
%%%assigning to stiv, see below :)
I work for HiRISE and I'm tired of not being able to view an actual DTM without a $50k piece of software that is a pain in the butt to work with anyway :)
I also figure that making the data easy for blender artists to use will result in cool fly throughs someday :)
DTM ?
Digital Terrain Model. (Also the term DEM is thrown around: s/Terrain/Elevation/)
examples: http://www.uahirise.org/dtm/
ah. that would have been my guess, coming from a GIS background, but figured it was something else
rootard, cool pix!
stiv, thanks! I'll pass it on to the folks upstairs.
in addition to gis, /me also has a thing for mars
stiv: that's great. With this plugin you can import surface models of Mars at 1m resolution if you have the memory for it. ;)
rootard, cool! a major savings on airfare! are these data sets specific to hirise?
There is another Mars project in the works (HiSCI) that will only produce stereo imagery and will likely use the same format. Also LRO uses the same .IMG format so you can probably get DTMs of the Moon and bring them in as well.
hey stiv maybe you haev time/will to review this one?
stiv you seem to have one with approriate background :)
mindrones, I'll try to take a look at it
stiv can I assign to you?
mindrones, sure. go ahead. time to step up my involvement again
stiv and wow! :)
%%%Help, I think my computer melted!
Downloaded the (400+ Mb) example file and ran the script. Seems to work as advertised.
A quick pass over the code does not show anything scary. The import * thing is generally frowned on, but minor.
The only suggestions I might make are to set the default bin size 12x12 so the unwary don't end up with a box of melted silicon and maybe a note in the warning header about being resource intensive.
Bottom line: seems like Good Stuff!%%%
%%%Hi Stephen,
Thanks,
%%%13:25 < stiv> rootard, if you have stuff you need committed, add it as a patch to the tracker ticket and I
I don't see how to attach files in the current invocation of the tracker so I have posted the patch here:
http://pirlwww.lpl.arizona.edu/~tims/io_convert_image_to_mesh_img.patch
Thanks!%%%
%%%Moved from Py Scripts Upload to Py Scripts Release%%%
%%%Hi, noting here the structure of the merger package we spoke about in irc with Valter:
io_convert_image_to_mesh_pds/
init.py
hirise/
init.py
import_img.py
lola_mola/
init.py
import_lro_mro.py%%%
%%%Hi!
Since your script is now in bf-extensions' svn (contrib|trunk) we have deleted the current attachments to avoid that end-users could reach this page and get the wrong version of your script.
Note that your script may have api changes or small maintenence changes applied in SVN.
Please retrieve your script from SVN before updating SVN to avoid mis-versioned scripts.
Thanks!
%%%Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
Added subscriber: @phaseIV-3
If anyone reads this, the functionality of the Hirise DTM importer has been restored.
The updated addon can be found at https://github.com/phaseIV/Blender-Hirise-DTM-Importer
Very timely with the current interest in Mars. I will check it out.
Thanks.
