Hi!
I have tried to do some updates into fbx importer. Now it should have proper index detection. And also it supports
edge weighting.
The lines that has edit in this area:(Lines 220-326)
When I started with the script I got some errors with line 370 and 387 so I took them into green. It issues with parent.
Thanks
Looked into your patch, but I cant test it because I don't have any sample files.
While trying some different files I ran into other problems with the original script.
- registration needed updating.
- parent matrix multiplication wasnt updated to new api.
- 'Scene' parent wasn't accounted for as being special
- Faces with 2 verts only need to be imported as edges.
I committed, leaving your lines in, commented with #EDGE:
So could you look into applying your patch against the updated script?
https://svn.blender.org/svnroot/bf-extensions/contrib/py/scripts/addons/io_import_fbx.py
can you provide an FBX test file for your script also with a screenshot of the correct result.
Hi!
Here is the latest script.It should support faces with 2 edges. Here is a simple test where is two meshes and one 2edge face.
Edge weight transfer ok from modo to blender. I haven't tested this with big fbx scenes.
Hi!
Bigger scene crash issue fixed. Script is updated. A lot of changes from the frist version. Also I included screenshot and sample file. The mans forehead has some
edge weighted edges. Works ok. Only things is that it took 38sec to load 5mb file. So it's quite slow. I could be interested to write this in c/c++ at some point. Needs to practise with python first and then learn c++ :)
I see that this tracker is closed, but still think this is the best place for my patch (import_fbx_cam.diff)
This imports the correct camera properties from FBX: Focal length, Sensor sizes and Film offset.
Tested with files from Maya and Cinema4D
Translation, rotation and animation hasn't been touched so still doesn't work yet.
