Image crop keyframes/fcurves do not 'stick' to strip *NEED BLEND FILE* #28158
2 Participants
Reference: blender/blender#28158
%%%In the sequence editor, fcurves for sequence strips are supposed to 'stick' to their strips, such that translating a strip left or right (forward or back) in time results in the same transformation to the fcurves for that strip.
For the image Crop properties (max_x,max_y,min_x,min_y) this is not the case, and the fcurves have to be moved manually.
Note: this in itself is a regression from 2.4 where you could have IPOs in 'scene time' or 'strip time' This is no longer possible in 2.4, and we have 'strip time' via mirrored translations- in theory we should be able to have a strip property flag (use_animation_lock) or similar, that allows fcurves associated with that strip to move with it or not. But this is a feature request, the original bug report still stands.
OS ubuntu 10.10, intel cpu, nvidia gfx, 64 bit.
%%%Works for me - note that this code didnt change recently, attached example blend file.
Could you please attach an example which fails?%%%
%%%Interesting, it's happening only on a (unfortunately huge) edit... will try to make it happen on a smaller file
%%%Suspect this is caused by a duplicate named sequence strip - which should never happen :S
Try rename the sequence strip to something you know is unique, then add fcurves and move.%%%
%%%Hi Campbell,
further testing on the file reveals it's something else
I think this happens because the strip in question is inside a metastrip - there are no duplicate names in the files (checked by looping over sequences_all in the console)
will see if the mere existance of a metastrip causes it in a new file, then report.
cheers
Bassam%%%
%%%Hi Campbell, further testing:
If you have a metastrip within a metastrip, and it has crop fcurves they do not move with the strip if you move the top level metastrip:
this doesn't happen to the top level metastrip
this doesn't happen to another type of strip (color) within the metastrip
%%%fixed r40652.%%%
%%%Thanks Campbell!%%%
