Crash when calling UNDO from a python script #28724
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#28724
%%%Blender uses to crash when I export some objects/meshes with an import/export python addon I've written.
Plugin structure:
I'm roughly using the following structure when exporting:
To sum up, the goal is to export the meshes' faces and vertices once they are tranformed by the modifers, scale factor, etc. (I don't know a better way to proceed than applying all transformations before exporting the data...)
Issue:
Blender uses to crash when I export some scenes with this plugin. It does not crash systematically, for example with the scene I'm supplying here, it crashes after 3 runs. With simpler scene (ie. not using modifiers, etc.), it never crashes.
As a note, I know when it's going to crash as Blender slows down and I hear my hdd suddenly getting busy (as if the OS is trying to swap memory, though the memory consumption remains quite stable - see the attached screenshot, Blender's Private Byte was around 50MB when it crashed - and there was not other running apps).
Steps to reproduce:
(I've attached a bare bones version of the plugin and a test scene, both are enough to trigger a crash on my system)
Workaround:
If I remove the "bpy.ops.ed.undo()" command from the addon and manually use the Ctrl+Z shortcut each time after running the addon, it works as expected and Blender never crashes.
%%%While this shouldn't crash,
Using undo in python isn't going to work well, you're most likely better off to make a copy, modify that, then throw it away.
or... not even copy it - you can just multiply the vertex location by the object.matrix_world to get their worldspace locations on export.
Like this:
wco = obj.matrix_world * vertex.co
%%%Thanks for the world matrix tip, Campbell. I was aware of this solution, but it can't fit for a simple reason: we don't get the full mesh as soon as a modifier is used (even a simple but heavily used one like mirror).
In the early development of this plugin, I was using dummy copies, as you also suggested. But as far as I remember, it was not very efficient. And deleting objects still leaves a lot of junk meshes as long as Blender is not restarted (though I think we can now delete them directly from python API).
Too bad. Any shot term / long term improvement foreseeable, or is it definitely hopeless?
A really nice solution would be to have a python way to access the meshes exactly as there are displayed in the scene (ie. after modifiers, scale, etc.) as those data are necessarily somewhere in memory. But I know this is not the place for feature request...
And if there's any test I could conduce or any process I should follow to help you locate the bug, please don't hesitate.%%%
%%%The most most common way to deal with it:
mesh = obj.to_mesh(scene, True, 'PREVIEW')
... export mesh data ...
bpy.data.meshes.remove(mesh)
see export_ply.py which comes with blender for the full example.
Undo is documented to be problematic with scripts: http://www.blender.org/documentation/blender_python_api_2_59_3/info_gotcha.html#undo-redo
Closing.%%%
%%%I was unaware of the Python API Gotchas document, which actually holds very valuable info.
Thanks a lot for pointing me out to the right direction.%%%
Changed status from 'Archived' to: 'Resolved'
