Fix SCons build on Fedora where Python is compiled with --wide-char ABI #30039
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#30039
%%%Without this patch, Blender fails to build on Fedora with SCons:
Using config file: build_files/scons/config/linux-config.py
user-config.py not found, no user overrides
Build with parallel jobs: 1
Build with debug symbols: False
Missing: "/usr/include/python3.2m/Python.h",
%%%At first glance, it looked like the python library suffix was not being set. Closer inspection reveals some fall-thru logic. It wold be nice if this was more explicit.%%%
%%%Made it more explicit - http://codereview.appspot.com/5610047/%%%
%%%The latest version is also attached.%%%
%%%It appeared that previous version didn't work, because there is no shell-like environment expansion in .py files.%%%
%%%Stivs assigning to you since Jesty has no blender time lately... %%%
%%%I've run into http://bugs.python.org/issue14049 and although it is closed, there doesn't seem to be a valid reason for closing the ticket. So, this should hang a little.%%%
%%%Fixed in r43992.%%%
%%%Revision 43992 ? Linkin test.%%%
%%%http://projects.blender.org/scm/viewvc.php?view=rev&root=bf-blender&revision=43992
Ticker can be closed now. Works on Fedora 16 too.%%%
