Map UV makes mapped images blurry #31868
Reference: blender/blender#31868
%%%Hi there,
I've attached a file to this bug report with a compositor setup that uses a MapUV node.
When I press F12 to render the composite image, the output from MapUV look unnecessarily blurry to me. The border of the UV mapped areas looks a bit odd too.
Cheers,
Chris
%%%Hi Chris!
Same result as blender 2.63a. What exactly is the bug? or is this more a feature request?
Best regards,
Jeroen%%%
%%%Hi Jeroen,
Thanks for responding!
I would say that the bug here is that the resulting image
looks so bad that it's unusable.
For comparison, I've attached a second file that compares
the output from a transform node with the output from MapUV
(press F12 to render). It's my contention that the output from
the transform node is the correct result, and that the MapUV
output is the wrong result. These two nodes should be
performing similar operations to get their results, so should
look roughly the same.
I will probably end up using the transform node instead of
the MapUV node in the project I'm working on, so for me
this isn't a showstopper. It's a pity though, since the MapUV
node allows you the convenience of placing an inset image
using geometry in object space.
Best regards,
Chris
%%%Since it's not a regression and it behaves in the same way since 2.50alpha0 i'd call this thing to be improved, not a bug.
Added to our TODO list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Tools#Compositing%%%
