Subdividing edges causes unwrap to "ignore" edge seam #31901
Reference: blender/blender#31901
%%%Windows Vista 64-bit
GeForce 9600 GT
Blender 2.63 R46461
Blender 2.63 R48065
RECREATION
From empty scene:
Add mesh/plane
Edit mode
Subdivide (1-cut)
Select the newly created edges
Mark edges as seams
Select the three parallel edges on one half of the plane (ex. on the left half, the three horizontal edges)
Subdivide those edges (1-cut) resulting in a plane with 6 faces
Select all
Unwrap
RESULT
This results in an unwrapped mesh with two quarters of the plane connected through the center vertex.
NOTE: It does NOT matter when you mark the seams. You can wait and mark them after the second subdivide and still re-create the issue.
DISCOVERY
Found after reworking topology on a moderately complex mesh. Used subdivide to create new vertices in a sub-region.%%%
%%%Antony, could you please glance at this issue? Thanks! :)%%%
%%%The issue, quite simply is the way our UV system works. The notion of UV islands is non persistent. Internally we have only a colection of MTFaces, NOT a collection of islands of MTFaces. What happens is that when you select a uv, it will automatically select any adjacent uvs whose vertex is the same, independently of the 'island' you thought they may be part of (Remember, there's no such thing as islands internally). To solve this properly we need to redesign the uv system to accomodate islands unfortunately (for which I have a few ideas). Other than that, as a workaround, I would try this:
The second unwrap remembers the margin setting and it will separate the islands, so selecting the uvs will behave correctly.
Sergey, should I close or mark as TODO?%%%
%%%Clarification, when selecting you will get coincident not adjacent uvs that share the same vertex.%%%
%%%Thanks for the work-around. Great job!
So, if unwrap had placed those islands in different places on the map, there wouldn't have been a problem (or at least not the same problem)? That explains why the connected islands seemed to change as I tried to fix the problem by changing the mesh. It was very confusing.
Glad you guys are around! :)
Thanks again.%%%
%%%Exactly, it was a different vertex sharing uvs in the same space for a different unwrap.%%%
%%%Marking as TODO%%%
