'invert' sensor option doesn't trigger controllers unless it's positive once #32181
Reference: blender/blender#32181
Category: Logic
%%%how to test it:
0) select the default cube
create an Int property and set value 37
create a property sensor - mode Equal, Prop: prop, Value: 37
connect it with a Motion Actuator with rotation 1 for Z
play the game, the cube will rotate
now select invert in the sensor and set the controller to NAnd.
play the game, the cube will not rotate
I consider that a bug, though it's been around since 2.49 at least.
The same happens if I use an Expression Controller: to replace the And controller use 'sensor=True' to replace the NAnd use 'sensor=False'
(replace sensor by the name of the sensor)
attached is a sample file demonstrating that in trunk (>2.63)
%%%note: setting Level to true makes it work as I expected. So maybe not a bug after all. thoughts?%%%
%%%note2 : setting pulse negative on also 'fixes' it. so yeah there are workarounds. Mitchell, any thoughts?%%%
Added subscriber: @JorgeBernalMartinez
I think this is not a "bug" related to the Nand controller. I mean, as you can see in the blend I've attached if you set it during runtime (pressing spacebar) the combination invert + Nand controller works right.
The issue I think is the following:
The initial State of the sensor seems that is set to FALSE. When you check for a TRUE condition (for example no "invert" press) at the beginning a pulse is generated. Also if you set the conditions during runtime it works OK.
But when you check at the beginning for a FALSE condition (invert button pressed) there is no change of state and no pulse is generated at the beginning. If you set it during runtime it works because the sensor state pass from a TRUE state to FALSE state and a pulse is generated.
BTW, If you check for FALSE condition (invert button pressed) with the false leveling pressed, it will work but it will do spending more processing resources as it will generate a pulse with each tick.
I think the possible solution would be setting the initial state of the sensor to something different to FALSE (i.e INITIAL_STATE) as it will generate a pulse at the beginning when it pass to TRUE or FALSE condition. I will check the code related to see if I can do a fix.
P.D. the best web page for BGE sensor pulses is http://gameblender.wikia.com/wiki/Sensors
Added subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
