Bad rendering of textured planes (and solidified too). #32648
Reference: blender/blender#32648
Category: Rendering
%%%Open the file.
Enter in Player.
Use the Arrow Keys to move the camera.
There're some examples.
At the left, bad rendering of texturede mesh, in the same object.
At the right, the same problem (I think) between two objects. To see this, move to left untill the above object appear to be behind the other.
Blender 2.63.18 and Stable version too.%%%
%%%The problem of the flag (left objects) can be fixed by turning off Transparency. But this is because this texture has no alpha channel. If it had transparency (like the objects of the right), the problem is still there.
Attached a simplier file (26b_texture_gl) to see how the texture is rendered EXACTLY BACKWARDS. Play and move the camera with arrow keys.
Thank you.%%%
%%%DON'T WASTE YOUR TIME OPENING THE FIRST TWO FILES. The problem is about Alpha Sort (I just check the docs). Some of this problems are fixed using this option. But...
I uploaded a third file ("c"), where there's no way of fixing the sorting with Alpha Sort in the two cases at the same time:
A.- two objects topped
B.- the same objects joined.
Both materials are with Alpha Sort. Entering in player (and quitting) several times, sometimes "B" is rendering well ("A" isn't), some other times, "A" is rendering well ("B" isn't). There's no configuration to make both cases to be rendered well.
Sorry of the two first posts and files. The title should change to "Bad rendering of Alpha Sorting".%%%
%%%I can confirm the bug here on OS X (Radeon Graphics) with Blender 2.64.
A temporary solution might be to use clip-alpha instead.%%%
File reuploaded: 26c_texture_gl.blend
Bug still on 2.75
15c301f
