Crash on Python console autocompletion #32692
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#32692
%%%Crash sometimes occurs when using Python console autocompletion. I did not managed to find exact reproduction scenarios, crashes occur spontaneously. Hope fault location will help:
blender[3648] general protection ip:1070205 sp:7fffdae10930 error:0 in blender[400000+3a26000]
System info file and loaded model file attached.%%%
%%%This is not enough info to redo the crash.
You need to give steps to redo the crash, even if it happens only one in 10 times, the steps you go through to get the crash to happen are really important.
marking as incomplete.%%%
%%%i can confirm (random?) crashes on auto-complete, but not provide any steps to reproduce it either.
IIRC, it happened for me when auto-completing variable attributes, and the variable was a ref to blender data, like:
var = bpy.context.object
do stuff here
var.<strg+spacebar> CRASH
the problem might have to do with a context, that changes over time, and accessing attributes might try to read from invalid memory address - but it's just a wild guess%%%
%%%This is likely invalid memory access: see
http://www.blender.org/documentation/blender_python_api_2_63_release/info_gotcha.html#edit-mode-memory-access
there is a cmake build time option that checks for this but slows down blender/python execution too. - WITH_PYTHON_SAFETY
closing. can re-open if you find steps to redo which are not accessing freed data (which is known limitation)%%%
%%%pretty sure it's invalid memory access:
Edit mode:
bpy.data.meshes['Cube'].polygons[0]
Object mode
bpy.data.meshes['Cube'].polygons[-292049]
auto-completing p does crash blender, as the reference is bad. So we just need to be careful with vars which refer to geometry and have been assigned in edit mode.%%%
Added subscriber: @demarcog83
Try this solution
https://developer.blender.org/T43491
