Pivot constraint does not work local
I appended an example file where i have four bones. The bone "pivot2" has two pivot constraints and should rotate around the left or right bone depending on it's own rotation. If you rotate "pivot2" then you should see how it should look like. But if i rotate the parent "pivot1" then "pivot2" starts moving without being rotated. I don't know if it is intended to be relative to the parent space or the bone himself, but either way the result is wrong and unusable.
Stuff I don't know... hopefully Joshua has a quick answer.
Note that I'm moving constraint issues to the wiki todo a lot. Too often options in constraints only work in controlled situations, not in every possible combination.
@Joshua Leung (aligorith), any clue here? Or shall we re-assign, move to TODO etc?
Joshua Leung (aligorith) closed this task as Archived.May 30 2014, 6:54 AM
Moving to TODO. We need to rethink this constraint.
