Segmentation fault after pasting a closed group of nodes into an open group #33628
Reference: blender/blender#33628
%%%Easy to reproduce:
open blender
set the rendering engine to Cycles Render
select an object (eg. the default cube)
clic on Material icon in Properties
clic Use Nodes
go to Node Editor (change the current view or add a new one... whatever)
create a node (eg. Noise Texture : Add > Texture > Noise Texture)
(you can add some other nodes but it has no influence)
select it (or them)
create a new group : CTRL+G
close the group : TAB
copy the group : CTRL+C
open the group : TAB
past the copied group : CTRL+V
Blender crash : Segmentation fault (core dumped)
%%%This operation should not be allowed, pasting a group into itself will give an infinite loop. Lukas, do we have a check for this?%%%
%%%Yeah, i was afraid somebody would try stuff like this sooner or later :S
Problem with preventing this case ("reentrant" node group, infinite recursion) is that we don't really have any kind of general system to check the validity of nodes in a specific context. All the checks that are done (e.g. group inside group, render layer only in base trees) are hacks on the operator level.
In the customnodes branch (aka "pynodes") i implemented a two-stage polling system for this purpose:
The system is not quite perfect, since an operator may want to create a node and then change settings, only to find out these settings are invalid (point in case: desired node group tree can not be used). But a generic poll system of some kind would be the way to go.
For now i can try to add a quick hack to the clipboard paste operator to prevent this case.%%%
%%%Just a try to avoïd the recursion: why not create a copy of the node instead of pasting the original one ?%%%
%%%It is making a copy of the node, but that node is still using the same node group, which is what it should be doing. Groups are nodes are meant to share their contents unless the group is explicitly duplicated by the user.
Lukas, I suggest just adding a quick check for this in the tool, or leave it as todo as part of pynodes merge.%%%
%%%Lukas:
If this will be fixed with the pyNodes merge, I guess we can close this here now and mark as todo for the remaining days? ;)%%%
%%%Still crashes with latest SVN, Lukas can you please check? %%%
%%%Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.%%%
