Ubuntu 12.10, ATI RV710
2.66 (official), no previous official version had the Rigid Body function I used
When enabling the new Rigid Body physics for a plane to let it collide with other objects, there is always a small distance between the plane and the other object.
(If you use the attached "planebug.blend", skip to step 5.)
1.) Open Blender.
2.) Add plane to default scene below the cube.
3.) Enable Rigid Body in physics for cube.
4.) Enable Rigid Body in physics for plane, and set type to "Passive".
5.) Press ALT+A to see the animation. The cube should fall onto the plane, but not touch it and always rest a little bit above it. I noticed this behaviour only for planes; cube-cube collisions work fine, for example.
Thank you!
Comment Actions
Thanks for the report.
This is not really a bug, using convex hull shapes for planes is just not working well if when embedding the collision margin.
It's better to use a mesh shape for passive planes. For acrive rigid bodies, objects with no volmue should be avoided, but you could use a box shape.
I'll look into making convex hulls work better for planes though.
