strange lines on 3D view on bezier curves with bevel object #34464
Reference: blender/blender#34464
windows 64 sp1 64bit, intel i7-3770 internal GPU on the CPU
blender-2.66-windows64.7z - with issue
blender-2.66-r54896-win64.zip - with issue
on my system with internal GPU, i have issues in the 3D View, when i am in wire-mode and some bezier curves have bevel objects applied.
on every redraw/update of the 3D View i get random lines in the viewport.
i tried all "Window Draw Mode", but all shows that issue.
i attached a blend file i was working with.
if it is too confusing:
0. open blender, - [x], - [x], [DEL], [ENTER]
switch to wire mode in the 3d viewport
[Shift]+- , - , - , create a bezier circle (for later use as bevel object)
[Shift]+- , - , - , create a bezier curve
[TAB] , enter edit mode
extrude 6 or more times.
[Alt]+- , to close the bezier curve to a cylic one.
put the created bezier circle as bevel object.
maybe you already will see some random lines in the 3d viewport... if not, add more points in the bezier curve and or create more bezier curves with bevel objects applied.
BUT maybe it is again a intel internal GPU issue...
%%%PS.: i just saw, it will also happen in solid view mode, when these curves are selected - than only the selection outlines are affected.%%%
%%%I can't reproduce this problem on a GTX 560 TI under Ubuntu 12.04. I might really be an Intel driver bug, but it could also be a bug in the drawing code that is not visible on Nvidia GPUs, because the drivers handle things a bit differently. %%%
%%%PS: Maybe you should test the same files with the software OpenGL script. If it also shows this drawing bugs, then it is most likely a bug in the drawing code.%%%
%%%Moved from Blender 2.6 Bug Tracker to OpenGL errors%%%
%%%loaded the file here on my GeForce GTS 450 and it works correctly.
moving to OpenGL errors.%%%
%%%sorry, i was searching long time for to find that thread again...
here some details of the graphic manager:
http://www.pasteall.org/40110/text
and i can not reproduce my issue on other computers / even not on the computer with exact the same hardware expect the graphiccard - the other system has an AMD HD 5670 graphiccard.
what do you mean with OpenGL script?%%%
%%%also issues in Blender Game Engine
there the blend i tested
http://pasteall.org/blend/19753
(it is from that thread http://www.blendernation.com/2013/03/02/studio-physics-demo/#utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+Blendernation+%28BlenderNation%29)
the bigger the window of the viewport is, the bigger are the issues...
(on the clone PC with none-gpu-on-cpu there is no that issue, so it is clear, it must be a problem with the internal-GPU -on-CPU of the intel i7-3770 or its driver)%%%
%%%[#35039] for additional info (specially the video)%%%
Added subscriber: @beta-tester
i noticed all the above shown issues (strange lines and game engine) do not exist in the same hardware but windows 8.1 64bit and blender 2.69.x.
i have no windows 7 anymore, so i don't know, if the issues are gone by newer intel graphic drivers or if the reason is in blender 2.69.x...
i only wanted to let you know...
