Proposed extensions to Property Chart addon #34624
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#34624
Group: Unstable (example)
%%%Hello Folks.
I started learning bpy API couple of weeks back and found that the Property Chart addon is very useful to investigating rna_type properties. While using the addon extensively, i needed some features for saving and loading presets and also an ability to have quick access to object properties to be added to the property chart. I went ahead and mocked up the idea. You can view the following youtube video that I recorded demonstrating my experiments.
http://www.youtube.com/watch?v=3ei6--0liE8
Have also attached a demo .blend file and diff.
I also made modifications to existing methods, as I was experimenting with the API.
Please let me know what you think. Thank You.
Cheers,
Satish.
%%%Hi Satish, I checked on the patch,
and while the functionality is definitely an improvement, there are a few things Im not sure about regarding the changes you made.
Some comments from checking the patch...
Id prefer to add these in as separate patches, eg
%%%Hello Campbell.
This is exactly the feedback I was looking for.
> what are the changes to obj_prop_get() needed for?
I was just testing to see if using path_resolve gives the same functionality. I stumbled across that method by accident and to test it, modified your method. We can roll it back to your version.
> agree with your comment in the video: using blenders presets are worth looking into.
I am going to work on that today.
> the buttons are very long/wordy, for eg, the button to add a new property could just be a '+' icon.
Agreed.
> adding a new property can be made to work like the spacebar operator search menu (give give you some pointers if you need).
Yes, that would be great. I am eager to some pointers.
Also, I was wondering if wildcards can be supported in the search menu, so that i can choose multiple properties at once.
Sounds good to me. I can do that.
Thank you.
Satish.%%%
%%%I started studying Blender's Presets architecture. Tracked the .py files where the abstract API and examples are defined.%%%
%%%Added Presets feature to the existing property chart addon.
Writing Preset: 'C:\Users\lenovo\AppData\Roaming\Blender Foundation\Blender\2.66\scripts\presets\sequencer\properties\default.py'
Writing Preset: 'C:\Users\lenovo\AppData\Roaming\Blender Foundation\Blender\2.66\scripts\presets\sequencer\properties\frames.py'
Writing Preset: 'C:\Users\lenovo\AppData\Roaming\Blender Foundation\Blender\2.66\scripts\presets\object\properties\material.py'
Writing Preset: 'C:\Users\lenovo\AppData\Roaming\Blender Foundation\Blender\2.66\scripts\presets\object\properties\rna_type_1.py'
Only issue is that, when switching between 3Dview and Sequencer, the Menu name does not change. Its because of the way I implemented only one menu class. I can create two menu types and get it working, but looking for alternatives. Any suggestions?%%%
%%%Attached: system_property_chart_with_presets.diff%%%
%%%Committed r4373. (with some very minor changes)
Made the preset dirs "system_property_chart_view3d", "system_property_chart_sequencer" so its more clear who owns the presets.
Keeping the ticket open so other features from the original patch can be submitted here.%%%
%%%Sounds good to me. Will work on further patches and update the tracker.
Thank You.%%%
Thanks for keeping this open even thought there was not much activity. I got busy with personal life and some crazy things happening at work. Things are settling down and I will look into the other features now.
Added subscriber: @Blendify
@ideasman42 is this still useful?
Added subscriber: @BrendonMurphy
Closing as archived.
@SatishGoda fell free to create a new task if this addon is still valid & developed.
