usePulseCollision does not work on Near and Radar sensor #35038
Reference: blender/blender#35038
Category: Logic
%%%usePulseCollision does not work on Near and Radar sensor.
Please find attached a test blend with near sensor.
TestCase:
Each time the near sensor triggers the controller the property "activations" will be inceased.
One sensed object is in sensor range from startup - detected at frame 0 -> property gets 1 in frame 1
Another sensed object moved into range at frame 0 - detected at frame 1
A) Without usePulseCollision the controller should not get activated -> property remains at 1
B) With usePulseCollision the controller should get activated -> property changed to 2
Both situations are tested
A) is fine
B) does not work
Remark: As there is no switch in GUI the sensor will be configured via Python controller.%%%
%%%BTW. I use Blender 2.66a on Windows
The same effect is on Linux.%%%
%%%I made a fix (NearSensor_usePulseCollision.patch) for this bug.
%%%very cool
Thanks%%%
%%%Tested with:
version 2.66 (sub 6), revision b'56420M'. b'Release'
build date: b'2013-04-30', b'21:31:38'
platform: b'Windows:32bit'
It failed the test.
Interestingly the first time I run the test it was successful. But all following test runs fail because missing activation. %%%
%%%I forgot: tested with:
%%%The properties "activations" are working correct on my PC.
But you need 4 frames to get the correct result from your script, because the collision sphere will be replaced with the "Reset Distance" sphere.
By the way. Every new pulse collision will react on the "Reset Distance" size because the sensor is still trigged.%%%
Added subscriber: @panzergame
@hg1 : Can you retest/commit your fix ?
At the weekend I will have a look at this.
Added subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
