snap align to reflection option #35069
9 Participants
Reference: blender/blender#35069
%%%this is a quick patch primarily aiming at making lighting/setting up reflections a bit easier.
In addition to the existing "snap align to surface normal" it indroduces a new option "snap align to reflection". This enables the user to just point at a position on a mesh and the light/emmitter will be positioned so that the resulting reflections will appear exactly where desired...
quick video showing this (there might be other usecases as well...)
https://vimeo.com/64733829
hope this is useful for others
Greetz
Philipp
%%%Hi Phillip,
I encountered fail building blender after apply your patch. This is the log after I used your patch http:*www.pasteall.org/41746 and this is the error log for make error http:*www.pasteall.org/41747%%%
%%%Hi Aditia!
Maybe something got malformatted (I had some other stuff in the diff I took out by hand...)
I have attached another patch. Does this one apply?
Greetz
Philipp%%%
%%%This is quite clever, simple idea but powerful. Some comments:
%%%Hi Brecht, and thanx for your comments!
I will try to address them in the following days (a bit busy atm...) and post and updated patch then.
Not quite sure how it would fit without using an empty (lamp would have to preserve distance to surface, not really something one would consider "snapping" anymore), but will think about it - maybe I can come up with something.%%%
%%%Tiny update (only now have time again) as v02:
patch updated to master
(after my migration to git here - I've also set up arcanist, if that helps)
TransformSnapReflection_91f0a38ad69149fb3e6c57e8a8c4ddff34c03f0f.diff
Added subscriber: @Sergey
The patch seems really nice to me, but would be cool if it's supported workflow where parenting to an empty is not needed. Any progress with that?
@Sergey: I made it an addon for the time being. It's working a little differently [more like a brush], but no empties needed here. Just select the lamp/emitter and launch the modal op.
If this is interesting for you/others, please give it a go [feedback really appreciated]. Might also be a fun exercise porting this back to C if this functionality is considered for inclusion...
note: addon is alpha/beta and not ready for primetime, but could very well serve as a reference on how to proceed from here
LichtwerkPlaceReflectionTool.py
quickstart:
What do you think?
I didn't test the addon yet, but from the description it sounds rather really handy and more clear. Would be nice to have it wrapped around and ended up in official addons repository.
Added subscriber: @zeauro
I tested the addon.
Display of the widget seems very complete and customizable. It works well.
The need to use middlemousescroll for adjusting strength is not obvious when you are only looking at the header.
It seems to be overcompilcated to hold F and scroll mouse wheel at same time.
Maybe you wanted user to be able to change distance and strength at same time but probably a trick to synchronize sliders would be more easy to use.
IMO, Shift F to change strength is more natural to somebody using sculpt and paint modes.
Strength slider does not work well with Cycles. It does not work if lamp don't have an emission node with a strength slider.
And value of the slider is still between 0 and 1 which does not correspond to ranges used for Cycles Lamps.
So if you want to decrease default point lamp, you quickly goes to negative values for the slider.
Maybe it could change value of color of lamp when it is not using nodes.
Cycles is a complicated case. If the tool becomes a kind of lighting setup mode, it should also take into account emitter size.
About that, color sliders or a call of color picker could also be a cool addition.
Problem is that you have to quit the mode, each time, you want to change a setting not taken into account by the addon.
Even with "Bend towards diffuse shading" slider, you have to quit mode. But it would be great to have it in interactive mode.
It is also a pity to quit to select another lamp that already exists.
IMO, switch through existing lamps could be a good use of mousewheel.
thanx for checking this out, @zeauro.
And thanx for the suggestions! I'll review this whole thing in depth in about a month from now (busy atm) and your suggestions will help a lot :)
Added subscriber: @FilipMond
That's awesome tool for product visualizations. great work :)
As zeauro said, would be more awesome to see distance adjustments in real. Strength already is, but I feel the same - slider is not corresponding to cycles range. Adjust Color on a fly sounds also great to me.
Another thing is - I wanted to post a bug, because I wasn't able to adjust strength, than I noticed this issue is related to Apples Magic Mouse. Classic (old) mouse wheel works.
Plus one private request - New light (Ctrl+LMB) generates a copy of selected object, would be helpful if copy will be with all setup of source. Like I created mesh light, thin long rectangle with disabled camera rays in object properties. But new generated object was original Plane.
Thank you
Just a quick test that made me happy :)
https://vimeo.com/154171370
Added subscriber: @cedriclepiller
This is nice,
Maybe :
If nothing selected, add a popup to select a light.
If a light is well placed, clic on F to change the distance and strenght without having to replace the light to apply those settings.
Maybe add a color picker to the F settings too.
Also when working on a pen, we cannot change the strengt, maybe make this in two times like sculpt
F = Distance
Ctrl + F = Strenght
Or you can create a popup with all the usefull settings of the light.
Thanx again for checking this out (and also for the very helpful feedback -- this will be considered once I find time for the next round of fixes/enhancements)
Cant really promise an exact deadline for this, anyways: seeing that people are actually interested pushes this as a priority for me for sure :)
Will keep you updated here.
similar add-on https://github.com/clarkx/Lumiere
Added subscriber: @AntonShushkov
Added subscriber: @dfelinto
Hi, thanks for your patch.
We are undergoing a Tracker Curfew where we are automatically closing old patches.
If you think the patch is still relevant please update and re-submit it. For new features make sure there is a clear design from the user level perspective.
FYI, third try at this: now working with the Light LookAt gizmo (which seems like a pretty natural choice) and it supports placing shadows, too:
D7971: [WIP] Light LookAt Gizmo Enhancements (place shadows, reflections, ...)
