mesh generator for round brilliant (diamond) objects #35389
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#35389
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.66
Category: Add Mesh
Python: 3.2
Script name: add_mesh_roundBrilliant.py
Dependencies: -
Author(s): dommetysk
Status: Open
%%%SCREENSHOTS
...are in attachment
INSTALLATION
Copy the file add_mesh_roundBrilliant.py into Blender/.blender/scripts/addons (Windows) or Blender/blender.app/Contents/MacOS/.blender/scripts/addons (OSX). Run blender, go into Blender User Preferences and select the Addons tab. Find the "Add Mesh: Brilliant" entry and activate the add-on by checking its checkbox.
USAGE
Once installed, move your mouse cursor into the 3D View and press Shift-A. Clicking Mesh > Brilliant will generate your object with the default or previous used parameters. A interface is provided in the tool bar (press T) where you can change all parameters (mesh will be updated accordingly) and also save presets. To best and most quickly understand each parameter, simply play around and see what each parameter does.
The following parameters are available:
Number of Segments default: 16
Table width default: 0.530
Crown height default: 0.162
Girdle thickness default: 0.017
Real Girdle default: False
Pavillion depth default: 0.431
Upper facet factor default: 0.250
Lower facet factor default: 0.450
Culet size default: 0.000
Retain lower angle default: False
MORE
The script is tested with blender version 2.67.
If you encounter any bugs, please contact me.
Thanks.
GIST:
https://gist.github.com/dommetysk/5585487
%%%I don't know how to update anything here on projects.blender.org
to download the latest version follow the above mentioned gist link.
thx%%%
most recent version (0.1.5)
moved to http://github.com/dommetysk/blender-add-brilliant
Added subscriber: @BrendonMurphy
hi, sorry for long delay here.
Merged into add_mesh_extra objects.
Please send any future updates here: https://developer.blender.org/maniphest/task/create/?project=3&type=Patch
Closing.
