Incredible destabilization of physics when using jointed objects with suspendDynamics() #35423
Reference: blender/blender#35423
Category: Physics
%%%Hello, this is my first bug report, registering on this site was something I was somehow trying to avoid for a long time, but I guess that it's now the time to do it.
Anyway, I'm here with a physics bug that came into Blender fairly soon after the 2.66 release, or around the time of the big Bullet Physics Engine upgrade and integration with the 3D viewport, and yes, this is with the Game Engine.
The .blend file should be pretty self-explanatory, there are two objects jointed together, when you play the game they will tumble over the ground and one of the objects will then have its physics suspended (and not the other one).
You will notice that as soon as the physics of that one object is disabled, the other object starts to go all over the place, this lasts for about 5-10 seconds of so before it finally settles down. I will also note that the bug also seems to manifest itself if the objects have enough time to hit the ground before the dynamics are suspended, if they are in midair, then nothing unusual will happen. I have apparently found a very limited choice of physics settings that allows avoidance of the bug in this case, but the expected behavior is broken for the other 99 percent of setting combinations and even then what prevents it here may not work for a larger setup.
I know the attached file uses the logic bricks to suspend the dynamics of one of the objects, but it also happens when one uses the suspendDynamics() function in Python as well. A final note is that I have confirmed that this bug will happen in any case involving a jointed setup where you suspend the dynamics of some objects, but not others, and I will remind you that this did indeed work as expected in the 2.66 release.
%%%I have attached a new file to demonstrate a much more complex case that (in 2.66 at least) demonstrates where it actually useful to suspend the dynamics of objects while they are jointed to other objects.
Someone on BA noted that this simple case seems resolved when 'compound' is checked, but for this rather complex case, this will not help at all as the code will generate joints for all objects. Let me just quote what I wrote there on what to do and what goes wrong.
"To see the issue in this file, uncomment the optimization in the code shown when opening the file. Sure, I can decide to not have those lines, but disabling the dynamics in certain cases is actually critical for maintaining performance for a high number of objects when the substeps value is higher than 1.
The whole idea here is to give games a joint-based destruction system that allows objects to break into arbitrary shapes when objects crash into them, this file worked in 2.66, but the building just explodes in 2.67. "
To note, it doesn't matter if there's a force acting against an active object connected to a suspended object, just the mere activation of some of the objects is enough to cause major initial jittering which then, according to the conditions where the code activates the objects, activates everything else and causes the whole building to explode.
If anyone here can look into this issue, look at both files, and ultimately fix the issue, it would be very appreciated.
Thanks.%%%
%%%Oops, I guess the file was too large for this site, I have the file uploaded here.
http://www.mediafire.com/?c9nfa4a4awzbnrd%%%
%%%Can't reproduce here on 64bit linux.
From what I understood, just open the file and press p to see the problem? Maybe I'm missing a step?
Please give your system info and try the latest buildbot version: http://builder.blender.org/download/
If there's a thread somewhere discussing the problem, it might be usefull to post the link to that as well.
Also, for bug reports small files that isolate the problem are mouch more usefull, you don't need to attach complex setups :)%%%
%%%Yes, just open the file and press 'P'. the one I uploaded initially (ie. the one that actually uses the projects.blender.org attachment system), does not require any user interaction (and is the most basic setup needed to show the issue). The other file does require interaction as it involves a ball that you can move into the buildings with the arrow keys (but as I said, the bug in that file wouldn't be seen until you uncomment the two lines of code shown in the text editor, which allows the jointed objects to have their physics disabled under certain conditions).
Also, this was just tested with the most recent buildbot build and I've seen no changes in behavior compared to the one I was initially using. This on a Win7 64 bit machine with 16 GB of RAM, an Ivy Bridge i7 processor, and a midrange ATI GPU.
BTW: The thread is here.
http://www.blenderartists.org/forum/showthread.php?291891-Anyone-else-get-this-Spaz-out-issues-with-jointed-objects-and-suspendDynamics%28%29%%%
%%%Ok, seems like a windows bug then.
I can't test this atm, at best I could make a patch based on guesses.%%%
%%%Hi again, I think I have a need to be even more specific, here is why.
I tested the file again with the MingW build I got from the buildbot yesterday (not the VC build) and the problem went away.
So not only is it specific to Windows builds, it's also more or less specific to those built with the Visual C 2008 compiler.
Hope that helps.
Added subscriber: @brita
@Ace_Dragon I was also not able to reproduce this on my linux machine.
Can you confirm if it is still happening on windows?
Hi. I had time to test the file again for post 2.71 builds.
The simple situation I posted is now completely stable in VC2013, but the complex file I posted still has major issues with blocks suddenly disappearing when the physics are continually suspended and restored.
If you have access to windows, you might try the larger file since it seems like the bug is now limited to larger setups (or at least would be harder to reproduce on simple cases).
Added subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
