Zcombine wrong alpha clipping since 2.67 #35586
6 Participants
Reference: blender/blender#35586
Windows 7 64bit, Nvidia 550ti
since 2.67 it works wrong/different. in 2.66a it has worked well (for me)
You can look in my blendfile. There are two renderlayers and they are put together with z combine node. When "use alpha" is activated the grid is nearly invisible in blender 2.67. In blender 2.66 it worked different/better. It seems if the clipping of the alpha channel changed but why? Its not the reason of different user preferences and i see no way to control it.
%%%The render layers all have alpha 1, so the "use alpha" in zcombine should simply have no effect.
Disable it for now to get it render fine.
Will ask Jeroen if he can find why this fails now.%%%
%%%when i disable alpha, i get white edges. %%%
%%%Seems to be related to cycles renders. Blender internal works fine. Cycles renders with narrow edges creates artifacts. Not sure why but could be uninitialized memory.
Z buffer seems to be correct.%%%
%%%According to Brecht, cycles has thinnier Z-Edges than Blender internal. So basically it is not an issue of the compositor, but on the input data.
%%%i remind : 2.66a it worked well%%%
%%%If this worked in 2.66, then this is a regression and should be fixed.
Brecht, could you check if this is really a problem of Cycles? %%%
%%%I discussed this with Jeroen on IRC. The problem is that the "antialiasing" Z Combine does is designed to work with Blender Internal Z passes but doesn't work well with Cycles. I wouldn't say either is wrong and personally think the Cycles Z pass make more sense (and it kind of shows by it not needing this antialiasing step as much).
It's a regression compared to 2.66 because it was actually broken for Blender Internal there, now that's fixed but it breaks behavior for Cycles again and works like the old compositor. Not sure what the best solution is, maybe this node should have an option to control the antialiasing. That's a bit annoying but I also don't like to change the Z pass of either Cycles or Blender Internal.%%%
%%%Add an option to the node now, you can disable it to get the result from the 2.64 to 2.66 releases.%%%
