Texture faces display white in 3D view, when used as a Particle Object #35810
6 Participants
Reference: blender/blender#35810
%%%Windows 7, Nvidia GTX580
Blender Version 2.67b
This is a minor display problem in the 3D view. A textured plane appears properly textured in the 3D view. But if the plane is used as a particle object its textures disappear in the 3D view and it is displayed pure white. This occurs only after saving and reloading the file.
I've attached screenshots and a sample Blend file. Set the particle object to 'none', reload the file, and the textures reappear.
Wayne%%%
%%%I had the same problem (both BI and cycles), is happening to the emitter object but also to the "dupli object" you use for particles (or hairs).%%%
%%%This happens also when the object is used duplicated with 'dupliverts'. I attached a similar sample file (BugDemo2.blend).
To see the bug alternate between 'None' and 'Verts' and save, reopen the file.%%%
Added subscriber: @Sergey
I couldn't reproduce the issue using 2.69 release and current development builds. Do you mind checking with recent blender version and updating instructions ifneeded?
I am still seeing the problem at 2.69 r60995 ( the current release build I think ).
If a textured mesh is used as a particle object, its textures won't appear in the 3D view after the file has been saved and reloaded.
The attached file, BugDemo.Blend, has a textured mesh 'Plane' ( face textures applied using a UV map ) . Such texturing would normally appear in the 3D view. However as soon as I assign Plane as a particle object on the larger EmissionPlane mesh, then save and reload the file, the texturing on 'Plane' disappears. This 'invisible texturing' occurs fairly universally for me, whenever a textured mesh is used as a particle object. And oddly, the issue doesn't occur until the file is saved and reloaded.
To demonstrate the problem:
To reverse the problem:
It might be just me - my PC setup etc ( Windows 7, Nvidia GTX580 ). Anyway its a minor enough problem, affecting appearance in the 3D view only.
Thanks for looking at it.
Wayne
Really weird. Could totally see the issue on linux now, but everything worked fine when i've been testing the file in my windows box. Hrrrm...
Will look into it.
Develoepr note:
Doublechecked on windows and textures indeed seems correct. Do have some suspecions about textures not working in GL display lists. Will look further.
Added subscriber: @brecht
Here's the patch which solves the issue: http://www.pasteall.org/49303/diff
However not sure why exactly this doesn't work. As in is it expected that OGL will texture objects nicely when calling displists?
@brecht, can you please have a look as well?
My best guess that this is a bug in the graphics driver or some invalid OpenGL state that we are using, but it's not clear which one. In principle textures should work with display lists, but I wouldn't be surprised if the particular way we used them has issues.
I'd consider this a workaround but I think it's reasonable until we do bigger OpenGL drawing changes, display lists are deprecated in new OpenGL versions anyway.
This issue was referenced by blender/blender-addons-contrib@6a4f2fd552
6a4f2fd552
Closed by commit
6a4f2fd552
.I can confirm the fix. I downloaded this morning's daily build:
blender-2.69-39ad2cd-win64.zip 76M Thu Feb 6 02:28:43 2014
and found the problem to be resolved.
Thanks!
