Data loss between saves for custom node trees #36024
Reference: blender/blender#36024
Ubuntu 13.04, Radeon HD 5000/6000/7350 Series
Nightly build, r58014
2.68-RC
No known working version.
Between saves, Blender appears to lose node tree/node data when using a simple custom node editor.
Expected behavior: changes persist
Observed behavior: node tree and nodes are missing
%%%This is standard Blender behavior, if a datablock has 0 users (as shown in the node menu), it will be removed by the garbage collector the next time you load the file. The same happens for materials, textures, meshes, .. . You can press the F (fake user) button to keep the nodes even if there is not other datablock using this node.
There is a big missing feature in the python API though, which is that you can't actually define create such links between datablocks yet. Hopefully that will be added soon, for now I guess the workaround is to enable the F button.
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.67/Python_Nodes%%%
%%%Yes, the issue with missing data block references (pointer properties) needs to be solved. However, it is not the actual issue in this case.
The problem has 2 parts:
This behavior was a precaution to avoid invalid data access, but should not actually be needed any longer. The editor will just display dummy nodes in flashy red warning color in case the types really don't get registered after loading.
Ultimately of course we want to link such trees in other places, at which point the bpy pointer property enters again. If you are interested, i've made a little workaround for "simulating" such properties (- [x], see IDRefProperty function and IDRefContainer decorator), example usage in - [x]. They simply store the name string and wrap a python property around it to return a true pointer, depending on property option also sets fake user by default to avoid user count problems.
The bug is fixed in SVN. Thanks for reporting!
