Relates to: T31555
Blender 2.68a,WinXp.
Addons do not work.
Relates to: T31555
Addons do not work.
Please make a real bug report, with precise description of the issue (“does not work” means nothing), example .blend file, steps to reproduce the problem, etc., etc.
File "C:\Program Files\Blender Foundation\Blender\2.68\scripts\startup\bl_ui\space_userpref.py", line 1145, in draw
addons = [(mod, addon_utils.module_bl_info(mod)) for mod in addon_utils.modules(addon_utils.addons_fake_modules)]
File "C:\Program Files\Blender Foundation\Blender\2.68\scripts\modules\addon_utils.py", line 178, in modules
force_support=force_support)
File "C:\Program Files\Blender Foundation\Blender\2.68\scripts\modules\addon_utils.py", line 143, in fake_module
"gives bad performance!: %r" % mod_path)
File "C:\Program Files\Blender Foundation\Blender\2.68\python\lib\encodings\cp866.py", line 19, in encode
return codecs.charmap_encode(input,self.errors,encoding_map)[0]
UnicodeEncodeError: 'charmap' codec can't encode character '\u0452' in position 91: character maps to <undefined>
Hey Ildar, sorry, did not saw the attachment… but yet, please be more descriptive in your report next time, it’s the first thing we see (and no need to copy that error log in messages either ;) ).
Now, back to topic, most likely you have in your path to Blender a char or more that cannot be converted to cp866 encoding. I’ll see how to fix this, but fixing this should make it work, in the mean time.
So, in fact, this is a known issue with current python and windows console - when embedded, you have no way to change standard inputs/outputs encoding. We have already another report related to same issue [#31555], so I’m going to close this one as duplicate.
Note we do have some hope that in py3.4 there will be a fix for this, but until then the only solution is to remove any special chars from your paths (pure-ascii paths should always work OK). :/
