CUDA error: Unknown error in cuCtxSynchronize() : does not recover #36986
Reference: blender/blender#36986
%%%I could reproduce this bug using windows xp 32 bit and linux 64 using a geforce gtx 580 card and there are many reporters of this bug, but noone i found used animations. I decided to open this report, because I came to the opinion that my observations are going deeper than those I found here, so that I cannot really say if they belong together.
the bug: while rendering an animation with cuda a cuCtxSynchronize-error occurs at some point and the following frames ain't rendered any more. it isn't always the same frame, but seems to be roughly after the same count of frames rendered. additionally i noticed, that glossy surfaces started to glow in purple without additional geometry entering the scene. in the console i found "CUDA error: Launch failed in cuMemFree(cuda_device_ptr(mem.device_pointer))" making me think, that there is a memory leak, which influences following frames in the animation. interesting: after canceling the rendering of the animation and redoing it it doesn't work and presents the same message immediately, but using the preview-renderer works fine AND after using it I am even able to continue rendering the animation! it seems to me as if all the code to reinit the cuda-engine is there, but should be executed before rendering any frame.
#38517 was marked as duplicate of this issue
%%%This file has Cache BVH and Persistent Images enabled, does disabling either of those avoid the problem (I suspect especially Persistent Images)?
Which exact Blender version are you testing this with?%%%
%%%Max, please get back to us on this. %%%
%%%I rerendered with Cache BVH and Persistent Images disabled, but the error appeared again. As a consequence I played around with the sampling and it seems as if I could avoid the cuCtxSynchronize-error by using less than 10 samples, although the purple glow fades in and suddenly disappears like before. How else can individual frames be linked? %%%
I think I found the issue! I had connected a
Glass BSDF
output to thecolor
input of aTransparent BSDF
node by accident. I found the messageby using my new script, which starts, renders and quits blender for each individual frame. I thought that might help, because I had more luck with individual frames than with rendering animations. Here comes the script:
batch-render.bat
:Notice: This batch creates a txt-file for each individual frame (see:
> %%N.TXT
), which can be used to review failures later on. I haven't seen the "error while rendering" message since than. That's why I am pretty sure it had to do with the message above.fail again. I found out, that the violet shine is introduced by ffmpeg when using it together with png graphics from blender. But the cuda error appeared again after I tweaked some render settings. Sadly my script doesn't work, because blender does not return a failure state as ERRORLEVEL/ return value, when the cuda error occurs. I will continue trying and keep you updated.
batch-render.sh
#!/bin/bash
Added subscriber: @ViktorForgacs
◀ Merged tasks: #38517.
Finally I had success rendering the scene!
I could fix that error by debugging my node setup. Sadly I cannot tell, what helped me, but:
After fixing these errors and some optimizations in the geometry, where i had a 'chink of light' AND after restarting my xorg server I was able to render all 1000 images without any error. It seems as if the xorg-server initialization would somehow reset the video cards memory.
