Quit prompt doesn't work #37017
5 Participants
Reference: blender/blender#37017
Windows 7 Pro 64bit, GF 670 GTX 2Gb VRAM
2.69RC1, never worked
When Quit Prompt check box is checked in the User Preferences (with saving settings or not), Blender doesn't show Quit Prompt Message and simply quits silently. It happens at any time whether I use Quit menu or close Blender by pressing X in the app's window header.
On the contrary, pressing Ctrl Q will always bring up Quit Prompt message, regardless if such option is active or not.
Launch Blender > File > User Preferences > Interface > check Prompt Quit > save settings > close preferences window > exit Blender via File > Quit or by closing app's window.
To see how Blender pops up Quit prompt regardless of option being activated using Ctrl Q:
Launch Blender > File > User Preferences > Interface > make sure Prompt Quit check box is unchecked > save settings > close preferences window > exit Blender via Ctrl Q%%%
%%%Seems like it's a smart function and it quits silently only on unchanged scene (clean scene or loaded scene that was not touched). Might want to close this as it's probably not a bug.%%%
%%%On my system (Win 7, 64bit, Blender 2.69 RC1) this is the behavior:
The prompt will not show if the scene is unchanged when you first open the file and then close Blender using the X at the top right of the window.
The prompt will show, if a change is made, and you try to close Blender using the X at the top right of the screen.
If you select File/quit from the menu, the prompt will not show, even if the scene has changed - bug
If you press CTRL+Q, the prompt will not show, even if the scene is changed - bug
It should prompt you if the scene has changed since opening or a save regardless of how you close Blender
This seems like a bug although it's the same behavior in 2.68a%%%
%%%Hi, it's not a bug.
First as already noted, the prompt only appears on changed scenes.
It is assumed that when user selects the quit entry from the menu he did that on purpose and really does want to quit, so no confirmation appears then (might be worth reconsidering that of course).
Having the prompt appear when the X button is pressed is done because the X button is filtered in a different, OS dependent way.
Ctrl-Q also should spawn a confirmation popup (not the same as the quit prompt though).
Also, even if user accidentally closes blender, the "recover last session" button on the file menu can remedy that easily.
Leaving this open for other gurus to decide if having no confirmation on menu pressing is (still) unwanted.
To be honest this had been discussed to the death already but since there's been a UI frenzy recently, let's see if any opinions are changed here...%%%
%%%As Andrew Price recently mentioned, I think it's a great idea and time to begin to start standardizing these critical features of Blender with the way every other Windows application works (and that goes for all other OSs as well).
Instead of it displaying "do you really want to quit?", have it display "Do you want to save your changes" with a YES/NO dialogue like every other Windows app.
The point of having the 'Save Changes?' alert is for one reason and one reason only: To alert the user that he/she has tried to close the application without saving the changes. MOST of the time, one will be in this situation because of an accidental key press or an assumption that no changes have been made, but were, or that the save was already done, but wasn't. Rarely would a user want to discard changes after hours of work. As all other Window's apps present an alert when the app is attempted to be closed without saving the changes, so should Blender to maintain conformity with Window's users. The user simply needs to click YES or NO.
Have it added as default behavior with the option to disable it in the app.
Again, let's get Blender to be forward instead of backward by default. Every Windows app asks the user to save changes if they haven't been upon closing. Every windows app selects with left mouse button. Standard = default, backwards is optional if you so desire.
Blender can remain completely unique and also maintain OS regularity which will help with streamlining workflow and making users less irritated.
As always, thank you very much for developing and maintaining this great product known as Blender.%%%
%%%I understand the importance of this, but this bug tracker is not the place to discuss UI design. Please send a proposals with the behavior you expect to bf-funboard:
http://lists.blender.org/mailman/listinfo/bf-funboard
We'll probably set up a better system for making such UI design decisions, but for now, please follow the bug submission guidelines, this bug tracker is for behavior that the developer intended to work but that is broken somehow.%%%
Added subscriber: @RomboutVersluijs
Hi there,
today i downloaded the new rv2,69. As i find the prompt quit very usefull and a good reminder. In the new revision it is totally left out on the mac, my lattest download is build r60991. I checked on blenderartist and windows users showed me screenshots of a function you can turn on and off.
