UI List can freeze blender #37442
Closed
opened 2013-11-14 14:08:11 +01:00 by Alexander N. · 8 comments
Member
Windows 8.1 64bit,
Broken: Blender 2.69
the ui list (template_list) can freeze blender, when the list sits on a non-enabled layout and you try to re-size the list.
  1. open attached blend file,
  2. run script
  3. try to enlarge the size of the list on the property panel on the right.
    ... blender freeze
issue_UI_List_freeze_blender.blend
issue_UI_List_freeze_blender.mp4
**System Information** Windows 8.1 64bit, **Blender Version** Broken: Blender 2.69 **Short description of error** the ui list (template_list) can freeze blender, when the list sits on a non-enabled layout and you try to re-size the list. **Exact steps for others to reproduce the error** 1. open attached blend file, 2. run script 3. try to enlarge the size of the list on the property panel on the right. ... blender freeze [issue_UI_List_freeze_blender.blend](https://archive.blender.org/developer/F27169/issue_UI_List_freeze_blender.blend) ![issue_UI_List_freeze_blender.PNG](https://archive.blender.org/developer/F27170/issue_UI_List_freeze_blender.PNG) [issue_UI_List_freeze_blender.mp4](https://archive.blender.org/developer/F27178/issue_UI_List_freeze_blender.mp4)
Author
Member
Author
Member
Added subscriber: @beta-tester
Added subscriber: @mont29
Confirmed, will assign to myself asap...
Bastien Montagne self-assigned this 2013-11-14 17:01:58 +01:00
Closed by commit d49498a461.
This issue was referenced by blender/blender-addons-contrib@d49498a461
This issue was referenced by blender/blender-addons-contrib@d49498a4612993b7821e62d5267e22b99f781b92
This issue was referenced by d49498a461
This issue was referenced by d49498a4612993b7821e62d5267e22b99f781b92
Reference: blender/blender#37442
