UV Editor simultaneously shows vertices and edges/faces; selecting elements using same techniques as in 3D view fails #37589
Reference: blender/blender#37589
Windows 7 Pro 64bit / GF 670 GTX 2Gb VRAM
Broken: Blender 2.69 rXXXXXX
Worked: never?
In the UV Editor, turning on Edges or Faces doesn't turn off Vertices, and thus loop selection operation as used in 3D View are not possible (only works with vertices, but doesn't work with Edges/Faces)
http://i.imgur.com/LlFUwt7.png
Start Blender, unwrap default cube (using seams), open UV Editor, select Faces selection element from the toolbar, try selecting faces using Alt Right Click UVcube.blend
Added subscriber: @motorsep
Added subscriber: @LukasTonne
AFAICT it's more of a missing feature rather than a bug. Loop select in UV edit currently only works with edges (relevant code section ).
Generally there is a difference between vertices in the 3D view and the UV editor: UV vertices are technically "corners", i.e. each face has its own set of vertices, multiple UV corners can be associated to the same mesh vertex. This might be a reason why face loops are not so easy to implement, but i can't tell for sure.
Added subscriber: @BartekMoniewski
Added subscriber: @brecht
This is a feature that has not been implemented in the UV editor yet. We would ideally like all relevant tools to be available in both and work consistent where possible, but this is not a bug.
Removed subscriber: @BartekMoniewski
