Specular material hardness influence for texture maps not working correctly or at all with certain specular types #37653
5 Participants
Reference: blender/blender#37653
windows 8
amd hd 7950
2.69
Texture maps set to influence material hardness amount not working with all specular shaders (wardlso toon) and ones that are working such as phong cook tor and blinn are not clamping to the same values as the hardness slider in the material panel. Ideally when a texture is used to pass a certain glossiness/hardness value to the shader it should bypass the hardness value in the material panel. A hardness value of one in the specular material panel should be the same as applying a pure black texture in the hardness influence setting this is not the case with the specular shaders at the moment.
It seems at the moment the range between a full black to full white texture and every value in-between only allows for a range between 30 to 90 with the hardness slider, where as hardness textures should clamp to the full range of the shader 1 ablsolute lowest value 511 absolute highest value
At the moment even when a texture is used say a pure black texture map to give the widest specular highlight possible its still possible to set the hardness value wider in the material properties.
Blender also has whiter hardness maps give wider highlights rather than darker hardness maps giving wider highlights this the reverse of the more standard for glossiness/hardness maps.
Ive made a blend with 3 texture maps set to influence hardness, a full white, full black, and a 50 percent grey to cycle though.
hardnesstester.blend
Added subscriber: @xonar
Added subscriber: @kupoman
Is this problem unique to the Game Engine, or does it apply to the viewport and the material system in general?
Initially I thought it was just related to the glsl view-port and game engine but blender render not cycles has the same problem, so its not just a game-engine thing. I'm quite surprised seeing its also this way in blender internal and it hasn't already been reported as a broken thing, as using a texture to control material glossiness/hardness over the surface of a model is something that's quite standard in the industry not just within games but pre-rendered work also.
Added subscriber: @JorgeBernalMartinez
This is really not a bug as this is the way how blender internal/bge works. I'll try explain from I remember when I implemented the wardiso shader almost 10 years ago :-)
The hardness_factor that you set in texture panel only affects in some grade to the hardness value that you can set for the specular shaders in material panel (moreover the hardness value depends on which blend type as Mix, Add, etc between other things that you have set). This hardness value only exists for Phong, CookTorr and Blinn specular shaders but not for WardIso and Toon shaders because as WardIso as Toon don't use the hardness value for anything when their respective specular values are calculated.
Maybe we should remove the hardness_factor when the wardiso & toon specular shaders are chosen.
Comment above is just for wardiso & toon shaders not working with hardness_factor.
For the other issue I will investigate deeper.
Added subscriber: @brita
Reading through and trying to summarize:
the hardness factor is not doing anything for wardiso and toon shaders -> that is as intended, if there is an interface problem, I couldn't see what.
Sliders and clamping: I see one slider in the texture panel, for the influence, clamping from 0 to 1. Looks correct. I see a slider for hardness in the material panel, depending on the selected specular shader (as it should be according to 1). The texture should override this value, and I never see it with incorrect values, so maybe I did not understood the problem.
Whiter maps give wider specular highlights instead of being black giving the widest -> testing gives me white=small (and focused), black=wide and more dismissive, as should be. Is this still a problem?
No this is still an issue. Tested again with buildbot version
b49e6d0
.(1) Yes correct lardloki stated those two shaders do not support texture hardness influence.
About (2) the 0 to 1 clamping in the hardness slider texture panel is not the reported issue but the clamping of the specular hardness slider in the specular shader to the textures hardness influence, which is a 1 to 511 range integer. Black to white texture brightness values can not give the same range of hardness "tightest highlight to widest highlight" when compared to the slider without a texture hardness influence.
A pure black texture does not influence the hardness value of the shader at all, it defaults to the value set with the hardness slider in the shader. This can tested with the current blend by activating the black texture then setting the hardness value in the specular shader itself to its highest value 511 to give the tightest hotspot, the black texture will not influence it "give the specular shader its widest hotspot".
(3) please disregard "Whiter maps give wider specular highlights instead of being black giving the widest" This works correctly.
Im not sure if were linking the same shaders from blender internal or weather or not they can be changed for just the bge to not affect the blenders render shaders as its not just a bge issue but an issue that affects blenders renderer also, but I see no reason to not have it fixed for blender internal also.
@xonar please tell me how to reproduce the bug in simple steps using that file. I am taking quite some time trying to understand..
Changed status from 'Resolved' to: 'Open'
I did not meant to close this, but set as incomplete.
Added subscriber: @mont29
No news since over a week…
