incorrect parameter description #37715
Closed
opened 2013-12-06 09:35:40 +01:00 by Alexander N. · 6 comments
Member
mathutils.geometry.distance_point_to_plane
there is written
 mathutils.geometry.distance_point_to_plane(pt, plane_co, plane_no)
    Returns the signed distance between a point and a plane (negative when below the normal).
    Parameters:
        pt (mathutils.Vector) – Point
        plane_co (mathutils.Vector) – First point of the quad
        plane_no (mathutils.Vector) – Second point of the quad
    Return type:
    float
but it should be the same parameter description as further down at mathutils.geometry.intersect_line_plane
plane_co (mathutils.Vector) – A point on the plane
plane_no (mathutils.Vector) – The direction the plane is facing
[mathutils.geometry.distance_point_to_plane ](http://www.blender.org/documentation/blender_python_api_2_69_3/mathutils.geometry.html?highlight=intersect#mathutils.geometry.distance_point_to_plane) there is written ``` mathutils.geometry.distance_point_to_plane(pt, plane_co, plane_no) Returns the signed distance between a point and a plane (negative when below the normal). Parameters: pt (mathutils.Vector) – Point plane_co (mathutils.Vector) – First point of the quad plane_no (mathutils.Vector) – Second point of the quad Return type: float ``` but it should be the same parameter description as further down at [mathutils.geometry.intersect_line_plane ](http://www.blender.org/documentation/blender_python_api_2_69_3/mathutils.geometry.html?highlight=intersect#mathutils.geometry.intersect_line_plane) ``` plane_co (mathutils.Vector) – A point on the plane plane_no (mathutils.Vector) – The direction the plane is facing ```
Author
Member
Author
Member
Added subscriber: @beta-tester
Campbell Barton was assigned by Brecht Van Lommel 2013-12-06 14:29:05 +01:00
This issue was referenced by blender/blender-addons-contrib@2ef3f6159c
This issue was referenced by blender/blender-addons-contrib@2ef3f6159ca2ead6b8c0fbc3d83d8eb42f2f5974
This issue was referenced by blender/blender@2ef3f6159c
This issue was referenced by blender/blender@2ef3f6159ca2ead6b8c0fbc3d83d8eb42f2f5974
Closed by commit blender/blender@2ef3f6159c.
Reference: blender/blender-addons#37715
