Scroll bar in text-editor shows the wrong mouse cursor #37867
5 Participants
Reference: blender/blender#37867
in text-editor when you got with the mouse cursor to the scroll-bar on the right side, the mouse-cursor does not change to the arrow-cursor as expected form normal behavior of scroll-bars outside of blender application.
issue_-_scroll_bar.blend
Added subscriber: @beta-tester
scroll bar in text-editor shows the wrong mouse cursorto Scroll bar in text-editor shows the wrong mouse cursorAdded subscriber: @brecht
I'm making this a To Do task, would be nice if it worked better but would not consider it a bug.
i would like to claim this as a very first task to dip into the blender code and get a bit of an idea of the patching process. if you are in need for this to be assigned to someone more competent, please take it! :)
Added subscriber: @Harshit-3
got back to try my luck on this task today.
so far found out how to change mouse cursor icon. the following function calls seem of relevance:
(where C is a pointer to bContext struct)
unfortunately since this is my first venture into the huge code base i am quite lost about where to put those calls...
in
text_ops.c
i foundtext_scroll_bar_invoke()
and putting it there makes it possible to change the cursor when the scrollbar is clicked, but nothing about when the mouse is hovering over it.Added subscriber: @NikoLeopold
i guess this would be easy for someone more experienced and since i don't want to destroy the code factorization through my limited knowledge i place this up for grabs again...
i would really love to know how this would be done however :)
I am also new to blender source code. I have spent some time working on this problem i.e studying various data structures used and event handles. I would like to grab it.
sure that would be great :)
id love to see how this should be done...
Added subscriber: @chipgw
this seems to work, but now the normal text input cursor flickers a little bit when moving the cursor around...
text_editor_scroll_cursor.patch
(BTW I'm new here, so this could very well NOT be the way it should be done.)
The method seems ok, two comments:
sa->spacetype == SPACE_TEXT
is not needed, this callback will only be called for the text space.win->eventstate->y - ar->winrct.ymin
for the Y coordinates? Not strictly needed but might as well not make any assumptions about the positioning of the scrollbar.For the flickering, I didn't see that here on OS X, I'm not sure how that would happen. You could check if it is actually it is actually setting a different value in text_cursor when it flickers, or if it's some other place calling WM_cursor_set that causes it, or if somehow calling WM_cursor_set with the same value multiple times causes the flicker.
the patch works nice for me! no flickering here either (also OS X).
interestingly enough, the second thing brecht suggested doesn't seem to work for me, don't really see why...
apparently the y part of st->txtscroll is something else, st->txtbar is the actual scrollbar rectangle.
text_editor_scrollbar_cursor.patch
this still has the slight flickering on ArchLinux KDE. it isn't a steady flicker, just every second or so it blips to the standard cursor and back, probably just for one frame.
EDIT: wait, now it bugs when there is no file open and therefore the scrollbar isn't visible.
EDIT2: checking st->text fixes that. (st->txtbar isn't set if st->text is null)
as far as I can tell the flicker problem is from
redefining the cursor every time it's called.
so sometimes the time between XFreeCursor and XDefineCursor/XFlush is long enough that the standard cursor is briefly visible. does this sound right?
That seems like a good hypothesis, perhaps the flicker can be avoided by delaying the
XFreeCursor
call like this: x11_custom_cursor_flicker.diffWe can also detect if the cursor shape actually changes before changing it in GHOST, but it really shouldn't be flickering to begin with.
Hm, I thought that would do it but apparently not. it even still happens if I comment out
XFreeCursor
completely. but it is only for custom cursors. with a different system one it's fine. (also if I set any of the node editor resize cursors to a custom cursor it flickers there as well)EDIT: it happens if I build with WITH_GHOST_SDL as well.
this almost works, but it doesn't change when switching screen layouts. text_editor_scrollbar_cursor.patch
so is passing
swin_changed
fromregion_cursor_set
a problem at all? this works without any issues as far as I can tell. text_editor_scrollbar_cursor.patch (I don't think the X11 flicker bug itself will be fixed short of only defining the cursor once at startup and reusing it)This issue was referenced by blender/blender-addons-contrib@19e74f1d4f
19e74f1d4f
Closed by commit
19e74f1d4f
.I committed a fix for the X11 mouse cursor problem, the problem was in the function that sets the cursor visibility (see
f04fd50073
).Committed the earlier patch now, thanks!
