Randomize (vertices) #38317
5 Participants
Reference: blender/blender#38317
This would be a simple tool to randomize all points in a mesh/lattice/armature/curves/metaballs even.
Using
ED_transverts.h
API this can be written once and used for for different object types. (See how warp and snap useED_transverts_create_from_obedit
and related functions).Changed status to: 'Open'
Added subscriber: @ideasman42
Added subscriber: @MarceloVaranda
A few questions:
1- Is it desired to have UI controls added into Property panel for each type of object or the idea is just to expose API and either an Addon or a script would call it?
2- As those object changes on the fly while in edit mode is it desired to randomize while being dynamically updated? It maybe confusing for the Artist as all vertices are changing position in areas not being modified; or lets only apply randomization when leaving edit-mode or by an function call?
3- any preference where to implement the wrappers for setting up the parameters (amplitude, frequency etc)?
Check object_warp.c
Posting a patch with a simple implementation that randomize vertices.
Still need work.
The sample code that I have attached moves vertices to/from the object center (maybe acceptable for rounded objects).
I guess it would be better moving along the vertices's normal but I did not dig enough to find where the normals are stored or calculated.
Added subscriber: @kevindietrich
You should at least claim the task if/when you're working on it. Just sayin'.
I am still getting familiar with everything related to this project. This saturday was my very first day working with Blender.
The claiming/assigning operation does not show up in the task's right panel... it is not obvious that we need to "Edit" the task to assign it. Thanks for the tip anyways.
Hi, some feedback on the patch,
First of all, I think randomizing around a central point is a bit strange. Probably best to just randomize each point in 3d space (move each vertex a random direction).
Also, randomizing in screen-space seems a bit unnecessary (I know warp does this, but its a special case - warp needs to be done in screen-space).
However it may be good to be able to constrain randomization, for example, randomized displacement along the vertex normal would be handy (like a noisy displacement).
Thanks Campbell, I will try to make progress on this task tomorrow. Is the place in the UI acceptable?
I am placing it in Mesh->Transform->Randomize
Thanks
Assigning to nobody as I may be too slow to complete this task.
I tried a couple things today but I went no where.
It looks like that it would make more sense to implement the desired code under mesh editor area if the operation should be performed over the object space.
ex: in a "editmesh_tools.c" like file having a function like "edbm_do_randomize_vertex_exec(...) "
However, it will be restricted to meshes and the suggestion was to apply to many object types
Anyways... if anyone else wants to help in implementing this task then please be welcome.
Added subscriber: @Cruentus_Nex
Added subscriber: @PatriceBertrand
Committed
2fc7d04804
closing.
