Blender 2.69.9 Crashes On Render F12 #38333
Reference: blender/blender#38333
Windows 7 x64 8GB
nVidia 460 GTX
Broken: blender-2.69-fd0b104-win64
Worked: (2.66)
Since the release of 2.69 Blender crashes on my Windows system and OSX when I press F12. I thought this such an obvious bug that others would report it but it seems to persist so I'll go ahead and file this report.
I pulled the above mentioned version down from buildbot today and unzipped it into my downloads folder. I double clicked on blender.exe and waited for it to come up. I click to dismiss the splash screen and press F12. It worked, the render of the default cube did not crash Blender! I thought yeah they have fixed the bug.
I proceed to move the above blender folder to my more permanent storage location for Blender and right-click on the EXE to send it to the desktop as a shortcut. I alter the shortcut to append the -con command line parameter so I can have both the console and Blender launched at the same time when I use Blender.
I conduct the same test using the shortcut icon. I launch Blender.exe using the shortcut and click to dismiss the splash screen then press F12. Blender crashes.
To sum it up.
If I launch blender by pasting the below path into the Start/Run box of Windows 7, then press F12, Blender does not crash.
C:\Users\Admin\Downloads\blender-2.69-fd0b104-win64\blender-2.69-fd0b104-win64\blender.exe
However,
If I paste the below code into the Start/Run box of Windows 7, then press F12, Blender DOES crash.
"E:\Documents and Settings\Admin\My Documents\Blender\26_Builds\blender-2.69-5611fb6-win64\blender.exe" -con
There is something wrong with pathing in this release of Blender that causes it to crash on render. Either the inclusion of spaces within a path, or path length, or launching from a shortcut...IDK
Added subscriber: @AtomP
Added subscriber: @brecht
I tried to redo this but couldn't. I have only a C: drive and no build from revision
5611fb6
, so I could only try to launch from"C:\Documents and Settings\Admin\My Documents\Blender\26_Builds\blender-2.69-fd0b104-win64\blender.exe" -con
Can any other Windows developer redo this? Is it the E: drive, the spaces in the path, the length of the path, the -con option, the older build revision, .. ?
Added subscribers: @ThomasDinges, @MartijnBerger
Added subscriber: @mont29
iirc,
5611fb6
is rather problematic… might be worth trying with a more recent build?Changed status from 'Open' to: 'Archived'
Ah yes, there was the render crash with boost paths. I'll assume this issue has been solved in newer version.
If there's a bug in newer versions I can reopen the report, but we need you to figure out which difference between the two commands causes the crash.
