Hair strands do not scale with model #38559
Reference: blender/blender#38559
64bit Linux Mint 16, kernel 3.11.0
GeForce GTX 650 Ti, driver version 319.32
Broken: 2.69.0 r60991
When a character model is scaled up or down, the hair strands on the character are not scaled with it. They retain the same size and orientation.
Additional Note
I am using blender to make a fantasy-themed comic, and it will have multiple cases of growth or shrinking spells being used. So, this issue impacts what I'm planning on doing and prevents me from using the hair simulation in place of ugly mesh hair.
Added subscriber: @ZauberParacelsus
That's by design unfortunately. I think it was a mistake, the particle/hair system has been designed to work in world space, while it really should work in object space. We don't consider that a bug at the moment, it will require a major refactor to fix that.
Do you have any suggestions for workarounds?
You could perhaps parent the particle object to another object, then the hairs do scale I think, though for thickness etc. you may need to create a driver as well.
Yeah, I've tried that already. Doesn't work, sadly.
Added subscriber: @brecht
@brecht I figured out a solution to this one. Instead of making the scale driver apply to the armature's root bone, I apply it to the scale of the armature itself. Doing it that way, nothing gets messed up at all.
EDIT: I think what's going on is that hair doesn't get properly affected by scaling with the armature modifier. Whereas if I just scale the armature itself, everything gets scaled through parenting relationships instead.
Added subscriber: @ShaunKreider
@ZauberParacelsus thanks for that work-around! This scaling issue has been getting in the way of using multiple characters in one scene that weren't exactly created proportionately to each other.
hey, i do have this same issue. When scaling down the armature works, but i want to scale down the root Bone. I tried by adding drivers to root bone to the armature scale, but it doesn't work. But i found one solution, convert the particle system into mesh, after that, convert it into curve and give some thickness, then decimate the hair as now it will be having a heavy number of polygons(something like around 50 Million! But your solution sounds more good and it will keep the polygons never increase, so that will help. It would be great if you can tell me how did you do it?
Thank you
That was 9 years ago... but I think my work around was to append the character into a scene and scale everything together in object mode to the needed size before working in pose mode.
hey. thank you for your reply, can't we do it any other way? the way it told you is very laggy
Scaling the root bone has the same effect as scaling everything in object mode though. Usually. Can't help you any further I stopped using bender hair years ago.
ok, thank you! now everything seems fine! thank you for your help
