Blender Prevents OSX Mavericks From Sleeping #38702
11 Participants
Reference: blender/blender#38702
OSX 10.9
Intel HD4000
Broken: (example: 2.69.10 who can remember a hash, revision numbers were more human friendly)
I am new to OSX but when I have Blender open OSX can never go to sleep or enter power management mode.
Open Blender on OSX 10.9 or better.
Hide Blender so it is no longer visible on the screen.
Walk away and get coffee and talk to people at the water cooler.
Go to sleep or wait and come back to the computer and you will find that the OSX machine has never entered sleep or screen saver mode. NOTE: Blender is not rendering, it is just sitting there idle.
I notice Adobe products do not have this problem and the system works fine with them.
Added subscriber: @AtomP
#65167 was marked as duplicate of this issue
#39813 was marked as duplicate of this issue
Added subscriber: @dfelinto
Added subscriber: @brecht
I can't redo the problem here on a MacBook Pro with NVidia 650M GT and OS X 10.9.1. I tried the Blender 2.69 release and the latest development version.
Does this happen with the default cube, just start Blender and it doesn't go to sleep, or only particular .blend files? Do you have any addons enabled that are causing this?
I tried with Blender open, minimized and hidden, but the machine always goes to sleep here.
Added subscriber: @bart-7
Use the following command to see which processes are keeping OS X going to sleep:
pmset -g assertions
I can actually confirm that after Blender fires up, the coreaudiod process becomes active and prevents entering sleep.
Here's the output without Blender running:
20-02-14 11:53:09 CET
After starting Blender, I see:
20-02-14 11:54:15 CET
Some system info: OS X 10.9.1, ATI Radeon HD 5750 1024 MB video card. Tested using 2.69 Release version with the default cube scene.
Added subscriber: @beetlegiest
Mine sleeps with blender open, minimized, etc OS X 10.9.1, AMD Radeon HD 6770M 1024 MB. Tested with release and master trunk. Can't make it not sleep as a matter of fact.
Hi
It is pretty clear that coreaudio prevents sleep here:
So i tested preferences audio and found openAL and SDL cause this, but not Jack ( and "drumroll": None )
So a workaround is to set audio to None or Jack atm. .
I will try to find out whats the background of this.
Jens
K, found this from stackoverflow, should be implemented in audaspace i guess:
Wiil take a deeper look hopefully before 2.7 release.
Will add Nexyon as he's the module owner.
Jens
Added Jörg ( not Peter, sorry ) as he needs to attend this for his audaspace library too.
Jens
Here's a suggestion:
#import <IOKit/pwr_mgt/IOPMLib.h>
kIOPMAssertionTypeNoDisplaySleep prevents display sleep, kIOPMAssertionTypeNoIdleSleep prevents idle sleep
reasonForActivity is a descriptive string used by the system whenever it needs to tell the user why the system is not sleeping. For example,
"Mail Compacting Mailboxes" would be a useful string. NOTE: IOPMAssertionCreateWithName limits the string to 128 characters.
Sources:
Added subscribers: @neXyon, @ThomasDinges
I'm not sure if adding such calls would solve the problem, it seems to be for preventing the OS from sleeping but we need to do the opposite. I think that it is the OpenAL or SDL libraries holding things up and that a fix can only be done there. But these are libraries typically used for games which will keep the OS awake anyway.
Maybe the solution is to lazily initialize the audio system and shut it down after it is not used for some time? Maybe that's too slow for starting playback, I don't know.
Added subscriber: @mont29
Added subscriber: @RustyWright
◀ Merged tasks: #39813.
Added subscriber: @Sergey
For sure we can try working this around, but i'm not sure why those libraries will ever affect on sleep on OSX, it doesn't happen on other systems..
Workaround would be to use None system backend as well.
Thanks for the report, but since the issue is actually in a library we don't maintain moving to a TODO http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Install-OS#Mac_OS_X
Added subscribers: @RedpaX, @jenkm
