Pinpointing crash related to T38913 and incomplete fix: crash avoided but array caps still not accounted for in collisions. #39056
5 Participants
Reference: blender/blender#39056
#38913.patch
#38913: BGE crashes when array with caps.
Crash is in CcdPhysicsController.cpp:UpdateMesh
In 4 places in this module array caps cause RAS_Polygon *poly to be incorrect.
This patch fixes the crash by skipping in such cases,
but the result is that caps are not accounted for in collisions.
So some more work is probably needed.
It seems there is a correspondance of faces after modifier applied to original faces of object. But in the case of caps, the original face does not belong to the object, it belongs to another object. I think it may be the only case where a modifier takes bits of another object. In the correspondance, the faces that have been generated from the caps have a corresponding original face of -1. In the code, this translates to:
return m_Polygons[num]`
RAS_Polygon* poly= meshobj->GetPolygon(origi);
with origi being -1. GetPolygon() simply does
So it may be that fixing this correctly would imply deeper changes to derived mesh handling, beyond my capacity.
Added subscriber: @PatriceBertrand
Added subscriber: @mont29
Added subscriber: @JorgeBernalMartinez
Added subscriber: @Blendify
@PatriceBertrand can you add this to the differential tool?
Added subscriber: @panzergame
@PatriceBertrand, currently the patch is useless because the negative index seems fixed in 2.76.1. See my comment in #38913.
Then it is safe to archive this and close the other task as resolved.
