Game engine bugs #39075
6 Participants
Reference: blender/blender#39075
windows 7 ult, 2.4gz celeron, 2gb ram, Geforce 8400 GS
blender 2.7
Short description of error 1
Collision sensor doesn't trigger properly when world/physics/physics steps/substeps is greater than 1.
Steps to reproduce 1
Create an object that constantly collides with another object. have either object have a collision sensor hooked to a "and" controller, which is hooked to some actuator that will change a property or do something. Start the game engine with substeps set higher than 1. You will see that the collision sensor isn't registering every collision.
Short description of error 2
A collision sensor is triggered twice: once on the initial collision, 2nd on the rebound (if there is a material physics elasticity greater than 0).
Steps to reproduce 2
Create a plane, scale it up a bit. Attach a material, enable Physics, then set the elasticity to 1.0. Set the physics type to Static, enable Collision Bounds, and set bounds type to Box. Create a cube. Set the physics type to Dynamic, enable Collision Bounds, and set bounds type to Box. Create a new Text in the script window. On the first line, type: print("test"). Add a collision sensor to the cube, then attach it to a Python controller. Set the Script box to Text. Run the game engine and notice that "test" is printed twice to the console.
Short description of error 3
Keyboard sensor sends a positive pulse twice because it registers both the keypress and key release. The same thing happens with the Mouse sensor, that it registers both the mouse button down and mouse button up.
Steps to reproduce 3
Create a new Text in the script window. On the first line, type: print("test"). Add a Keyboard sensor to the cube. Set the Key to whatever you want (spacebar for example). Attach it to a Python controller. Set the Script box to Text. Run the game and press the keyboard key you set it to. Notice that "test" is printed twice to the console.
Short description of error 4
A Message sensor is triggered twice when it receives a message.
Steps to reproduce 4
Create a cube. Add a Message sensor and connect it to a python controller. Create a new text block and type in the following:
from bge import logic
cont = logic.getCurrentController()
obj = cont.owner
print("test", obj['prop'])
Short description of error 5
In a script, changes to a KX_VertexProxy color, in GLSL mode, produces no visual changes even if vertex colors are enabled on the object. This works in Multitexture mode; however, the effect seems to apply on one polygon (it should apply on all polygons that share the vertex).
Short description of error 6
Material physics properties (friction, elasticity) apply, even if the material physics is disabled. Objects that use the triangle mesh collision type don't work unless Material physics is enabled.
Steps to reproduce 6
Create a cube and scale it along its Y axis a ways. Position it somewhere along the -X axis. Set the physics to Static and enable "Collision Bounds" then set the type to Box. In the material settings, add a new material and disable its Physics. Create a UV Sphere. Scale it down a ways. Set the Physics type to Dynamic. Enable "Collision Bounds" and set the type to Sphere. Go into wireframe mode and lower the Attributes/Radius down until you see the dotted circle is close to the sphere's edge. Create a new material and disable its physics. Attach a "Always" sensor, hook it to a "And" controller, then hook it to a "Motion" actuator. Set the Motion Force to -6.0 in the X field. Run the game engine and notice the sphere colliding the box and not bouncing. On the sphere, change the Material/Physics Elasticity to 1.0 and don't enable physics. Run the simulation again, the same result. Enable Material/Physics and run the simulation. Same result. Now select the box and set the Material/Physics Elasticity to 1.0 and don't enable physics. Run the simulation and notice the sphere bounce off the cube. You can see the problem, that both objects need Elasticity to be set greater than 0 to get results, regardless if Material/Physics is enabled or disabled.
Short description of error 7
If a child object (has a parent) that is connected to a edit object actuator->add object, is scaled, it adds objects that are also scaled. I don't know if this is supposed to happen or is a bug.
Short description of error 8
In scripting, assigned attributes to bge.logic are not cleaned up when exiting from the standalone player (might be only bge.texture specific). When exiting after a bge.texture and source are assigned to bge.logic, it generates the following error: Error Totblock: 2
This is fixed using the atexit module to call a function on exiting. The callback function deletes the attribute from bge.logic. The code is attacked to a Python controller and hooked to a "Always" sensor, with "True level triggering" enabled, and Frequency set to 2. The following code generates the error without the "cleanup" function.
from bge import texture, logic
from atexit import register
def cleanup():
if hasattr(logic, 'video'):
delattr(logic, 'video')
def playVideo():
obj = cont.owner
if not cont.sensors['Delay'].positive:
return
- the creation of the texture must be done once: save the
- texture object in an attribute of bge.logic module makes it persistent
if not hasattr(logic, 'video'):
- register(cleanup) # atexit function. Without this. an error is printed to the console
- identify a static texture by name
matID = texture.materialID(obj, 'IMstars1_still.jpg')
# create a dynamic texture that will replace the static texture
logic.video = texture.Texture(obj, matID)
# define a source of image for the texture, here a movie
movie = 'C:\blender\projects\tunnel_output\stars.avi'
logic.video.source = texture.VideoFFmpeg(movie)
#logic.video.source.scale = True
logic.video.source.repeat = -1
# quick off the movie, but it wont play in the background
logic.video.source.play()
playVideo()
Short description of error 9
After I recorded animation with "Record Animation" both enabled on the Game menu and object physics properties, it doesn't update or show that I have an animation until I scrub the keyframes or switch windows.
Short description of error 10
Physics->Lock Translation doesn't seem to work.
Short description of error 11
Text Curves are rendered larger in the bge than their viewport scale; and, materials/textures are not applied.
Short description of error 12
A bounding box with dotted lines covers my objects just outside their edges as shown in the 2 images. I discovered they are collision bounds; but, it makes my objects look very aliased in the viewport. Adjusting the margin doesn't show any changes in the viewport.
Added subscriber: @remnar
We expect 1 bug only per report, but I will leave this to the Game Engine developers. ;)
Added subscriber: @mont29
Added subscribers: @Moguri, @Sergey
Please on bug per report in the future.
@Moguri, i'll assign it to you and let you to poke other devs if needed :)
Added subscriber: @JorgeBernalMartinez
Scripts actually run twice. Once when the sensor is positive and again when it is negative. Create a reference to the sensor and then check if it is positive.
The comment above is valid for issues 2, 3 and 4
These really should be separate reports since we have no way to track the status on the individual issues in this report. I cannot reproduce issue 1 (I've attached the file I used), and as mentioned 2-4 have already been invalidated. I think 11 might be a duplicate bug report, and most of these could really use some example files. In short, this report is a mess. I'm thinking about closing it as invalid.
This was my first report, in that I thought that I needed to get out everything I observed. I didn't want to write up a bunch of redundant info. But now that I realize it, that these reports could be assigned to different people to work on, so I have been reporting one thing at a time. However, I am thinking that why should I have to included test files. Can't you test your own software? I am willing meet you half way but it is difficult to explain these things and gets quite frustrating.
I'm going to close this bug. If there are still bugs left in here that have do not have other reports, please make reports for them. As for why it is helpful to supply a blendfile, it makes it very obvious to reproduce the bug, and it saves us time. Also, we have a lot of reports to go through, so anything that helps make triage and fixing easier is extremely helpful. Also, we do test our software, but bugs still slip out. We definitely could do better with automated testing and such, but for now we have to work with what we have.
