Implement UnitTesting for UI Units handling, and improve it #39267
1 Participants
Reference: blender/blender#39267
So, related to #38722 and proposed fix (D340), I talked a bit with Campbell and he suggested to first expose 'units' in bpy, and create a test for it.
Test should gather a bunch of expressions and their desired result, to check what's currently working, what’s currently broken, and how this change when we modify underlying C code.
I made a quick prototype for this: D416. For now, it only contains trivial tests (two input, one know as broken, and one output). The main purpose of this design task is to gather a representative set of inputs (text to value) and outputs (value to text), that would made a good testing base for this code.
API
Exposed in
bpy.utils.units
. For now, I kept it simple:*
str_to_value(unit_system, unit_type, str_input, str_ref_unit=None)
to parse string into a float value.*
value_to_str(unit_system, unit_type, value, precision=3, split_unit=False, compatible_unit=False)
to print a float value into a string with units.*
systems
is a named tuple gathering all known unit systems ('NONE', 'METRIC', etc.).*
types
is a named tuple gathering all known unit types ('LENGTH', 'AREA', 'ROTATION', etc.).Tests
Tests are a mere tuple of tuples.
For each input test, you have:
This mimics current parameters of new
bpy.utils.units.str_to_value
function.E.g.:
('IMPERIAL', 'LENGTH', "", "1ft", 0.3048)
For each output test, you have:
bpy.utils.units.value_to_str
function.E.g.:
('IMPERIAL', 'LENGTH', 3, False, False, 0.3048, "1'")
Added subscribers: @mont29, @JonathanWilliamson, @ideasman42
Fixed/closed by
8535b9bd15
