Copy rot constraint does not update bone local axis for ensuing constraints/drivers #39456
Reference: blender/blender#39456
w7x64 gtx680
Broken: (2.70 release)
I'm not sure what is going on here so the title might be misleading, apologies.
Drivers or constraints that affect location of a bone and come after a copy rotation constraint do not move the bone according to the constrained rotation (as if the bone was not rotated), even though drivers or constraints are set to local space and are arranged in correct order.
It can be worked around by using an offset bone (parent takes Z rotation, child moves on local Y) but one of the big upsides of Blender rigging system is that you don't need them (thanks to local vs. transform space).
I also noticed the units in the "transformation" constraint do not change along when the transformation type is changed to rot or scale (it stays in meters and centimeters).
RotateZ the top bone (Bone.001), the small joint bone (Bone.002) should move along its local Y (constrained) axis, instead it just moves horizontally. In the example I used a transformation constraint but I tried with a driver on LocY and it's the same.
Hadrien
constraintLocalSpace.blend
Added subscriber: @hadrien
Added subscribers: @mont29, @Sergey
@mont29, you are one of few who're familiar with the bones. Is it something you can help with? :)
Added subscriber: @JoshuaLeung
Would like to summon you here, Joshua! :)
As far as I know, the whole constraints are evaluated in the org objects’s space (that what makes
BKE_constraint_mat_convertspace()
, at least).The same goes for transform (from drivers or fcurves), but this is to be expected (transform orientation only affects transform tools in 3DView, nothing related to animations or so here).
So all this looks more like internal limitation than bug, to me? Though I wonder a bit why not reusing cob matrix in case of constraints, when doing space conversions? That would make constraints behave more like a stack - and open yet another can of worms probably…
Closing as archived for now. Anyway, this is not a bug. Might be considered as TODO, but it would most likely break all existing files so…
Thanks for the clarification Bastien.
