Wrong UV texture coordinates when importing VRML file #39596
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#39596
MacOSX 10.6.8 on Apple MacBook 6,1
Broken: 2.70 19e627c
The VRML importer provided as an add-on with blender doesn't import texture coordinates properly : the texture coordinates indices are off by 1.
- start blender
- import a VRML scene that contains texture nodes (for example, fig6.vrml that I uploaded with the case #39594 : once the fix to #39594 is applied, we can see in blender that the texture doesn't display properly (the 4 texture coordinates are off by 1), although this scene is displayed properly with the FreeWRL software)
I attached the patch that I made. This patch fixes this bug, but I beleive that there are some other similar bugs remaining, as this bug seems to have been introduced in an attempt to fix bug blender/blender#18329, as it was tagged with the string 'EEKADOODLE'
texcoords_patch_to_v20131007.patch
texcoords_patch_to_v20131007.unifiedpatch
Added subscriber: @graffy
Added subscriber: @jonim8or
Are you sure the UVs in your file fig6.vrml are correct? because the uvs from the laetetia model http://www.web3d.org/x3d/content/examples/Basic/StudentProjects/_pages/page23.html appear to be imported fine. (and get broken with your version)
To be honest, I'm not 100% percent sure that fig6.vrml has correct UVs (this vrml file has been generated by mayavi, which is based on vtk, so there might well be a bug in their code). The only reason that makes me think that fig6.vrml is correct is that the UVs look fine when loaded into FreeWRL (http://en.wikipedia.org/wiki/FreeWRL), which seems serious enough...
The Laetetia model http://www.web3d.org/x3d/content/examples/Basic/StudentProjects/_pages/page23.html appears fine in FreeWRL, which seems to confirm that this model contains proper vrml.
As a result, it seems that my patch is suboptimal : it breaks laetitia import while it fixes fig6.vrml.
On a side note when made my 'fix', I noticed that a dummy texture coordinates pair was added to the list of textures coordinates in order to fix the 1-based indices issue. This is quite messy and I don't think this is necessary. Unless I overlooked something, this issue can be solved solely by using additions to UV coordinates indices (keep all python lists 0-based, and adapt indices only at the vrml parsing stage if vrml's indices are 1-based)
I really wonder if the tex coords are 1-based. From the vrml specification I understand that they are 0-based:
That should also go for the vertex colors, according to the specification. But I guess there's a reason why the eekadoodle was added.
In my version of the importer #38261 I have removed the dummy entry for uvs, and the "+ 1" that was done when referring to them. And it seems to work (with the laetitia model).
Added subscriber: @BrendonMurphy
closing as archived, no activity 1.5 years
